Question about Tivoli Kloss Model One AM/FM Radio
Tivoli model 1 low volume - Tivoli Kloss Model One AM/FM Radio
2 Suggested Answers
SOURCE: Tivoli iPal
send it back! I have had 2 fail this way.
Posted on Feb 28, 2008
Tivoli model Satellite will not turn on. Had intermittant power issues. Moved the radio and it will no longer power on
The power control problem is easy to fix.
It can as simple as a fuse (I'm sure you check it already) or a switch that is piggy back on the volume control.
Radio Shack has a similar one HERE
Disconnect the AC outlet and open the main Tivoli unit.
Look at the back side of the volume switch and you will see a power switch piggy back onto the volume control.
You can bypass it or get the correct value Potentiometer + SPST switch.
Use an ohm meter to meter the both end of the potentiometer and if it's 10,000 ohm or 10k then just go to Radio Shack and ask for
10K-Ohm Audio Control Potentiometer with SPST Switch Model: 271-215 | Catalog #: 271-215
It's a direct replacement.
If the ohm read is other then 10K then you will need to order it for an electronic supply house.
Tivoli makes great radio.....if you want to sell it I want the first dip.
Jul 30, 2010 | Tivoli Henry Kloss Model Two FM/AM Radio
My Tivoli Model One makes a loud screech/buzz noise
I had the same problem and was able to repair it quite easily. Only thing needed is some basic soldering skills.
Problem description:
  • Suddenly a quite loud and disturbing (scratch/screech/buzz) noise appears.
  • Sometimes the noise is gone but it reappears sooner or later.
  • Changing volume or radio band / input (am, fm, aux) does not affect the noise (even on volume turned down all the way).
  • The signal coming out of the Headphones / Rec Out plug is not affected.
Cause:
  • Cold solder joints
Solution:
  • Unplug from mains
  • Remove back panel (the two black screws next to the plugs in the center). The back panel sticks quite firmly, so it might help to remove the front panel first (the 4 screws in the corners) and carefully press out the back panel from the inside. (The other two (silver) screws are used to attach the transformer to the back panel) and need not to be loosened.)
  • On the circuit board at the back panel locate the plug that goes to the speaker (is says "J2"). Check the solder joints. In my case, looking closely, I could see that they're not good anymore.
  • Renew the joints by heating them up and applying some fresh soldering tin. I also renewd the joint from the wire bridge next to the plug. Just check the other solder joints on the board.
In my case afterwards the problem was gone and the device is working properly again.
Apr 03, 2010 | Tivoli Kloss Model One AM/FM Radio
Get a lot of static when try and turn volume down low.....in fact, sometimes it is hard to get sound when you turn the volume down....it is either full blast or silent.....lots of static like noise when...
This is an easy fix with a can of volume knob cleaner i think its called. You should be able to get it at radio shack. You just spray it into the volume knob and let it dry. The instructions are on the can.
Dec 03, 2009 | Tivoli Kloss Model One AM/FM Radio
Tivoli Model one radio - volume control does not go to quiet. I like to listen at night but volume does not lessen past a certain point which is too loud.
I noticed the same problem after I had moved. Hadn't had it before. The solution was easy in my case. (It took some time to accidentally figure it out though). I flipped the power cable around 180 degrees / upside down and re-connected. After this the volume worked as before. This was the model with European power plug.
Mar 01, 2009 | Tivoli Kloss Model One AM/FM Radio
Tivoli model two - low/no sound in base unit
I have exactly the same problem but found two work arounds, either one that I am completely satisfied. 1. unplug and replug the AC.
2. I have a subwoofer, when I plug the subwoofer cable half way in, the sounds of the base speak goes back to normal (but not all the way in)
Dec 26, 2008 | Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli Radio,
Does your radio have a sleep button or option? If so, check to make sure that you did not set it on accident or with out knowing. Or if it has batteries, check them to make sure they aren't dead or mixed with old or new.
Oct 21, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Tivoli Radio "Model One" Volume Problem
TRY SPRAYING A LITTLE CONTACT CLEANER ON THE VOLUME CONTROLL
I EVEN USED RUBBING ALCOHOL.
Mar 23, 2008 | Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli iPal
Nov 13, 2007 | Tivoli (PAL) AM/FM Radio
Tivoli Kloss Model One AM/FM Radio Logo
37 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Electro Med Services...
KC135Nav
Level 1 Expert
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
