Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Stuck bit I have a hex bit stuck in the quick realese chuck, the chuch sleve part won't pull forward
  • spreighmen Nov 16, 2007
    yes the bit is from deckmate screws. I can not get it out.
  • Anonymous Nov 19, 2007
    I used a short bit from my assortment because I needed to match a precise screw head. The bit pushed in too far and now I am unable to pull it out.
I HAD THE SAME PROBLEM AND STILL DO FROM TIME TO TIME. I USE THE PROPPER BITS, SO THAT ISNT THE PROBLEM.
WHAT WORKS IN GETTING THEM OUT... JUST TAP THE BIT INTO THE CHUCK AND THEN PULL THE QUICK RELEASE AND THE BIT COMES RIGHT OUT. THE BIT JUST GETS INTO A BIND AND TAPPING THE END FREES IT UP
Posted on Aug 09, 2008
I saw this on another post, but I can't find it any more.
Same thing happened to me, in a fit of impatience I used a short phillips hex bit and it pushed in too far and got stuck. No amount of pulling will get it out. Tried diagonals, vise, needlenose, etc. Also tried taking it apart but was stymied by the retaining ring.
What worked: Large flat-balde screwdriver prying the chuck collar up, while simultaneously pulling on the bit with a sharp diagnonal pliers. Popped right out.
Posted on May 11, 2008
I have two suggestions regarding the chuck stuck:
First I was told by a repair place to lube the quick chuck frequently as they quickly oxidize..
Second, after one of my snap chucks got too badly worn, I found a repair place that would take my 80 bucks to fix..ah no. Ereplacementparts.com had all the parts for 6.58 and the driver is very easy to repair yourself. The motor is also under 40 bucks if your run them everyday like I do...
Posted on Dec 09, 2007
I have the deckmate bit jammed in mine and my friends. He got hs bit out using 2 people one guy used a pair of sharp diagonals and held them tight on the bit and the other pushed the chuck out. They basically played tug a war and it popped out. On mine I removed the chuck by pushing in the washer on the end and using a small screwdriver to remove the retaining ring so that I could get the ball out. My bit was still jammed good so I ended up welding a rod to the end of the bit and putting that in a vise and tapping on the chuck with a hammer . You need to use an extention with a slot cut in it for proper use. Good Luck
Posted on Nov 22, 2007
Yeah that happened to me, I took it in for warranty and they hounored it, basically what happens is the bit gets pushed back past the ball bearing that holds it in in the first place, so the only way to get it out is to take the tool into a place and have them dissassemble the chuck and remove the bit, if you pull on on or try to pry it out yourself you risk damaging the inside components,
Posted on Nov 20, 2007
    Champion:
  • 313 Answers
You are not suppose to insert the tiny bit directly to the tool.
all you need is a 2" magnetic bit holder.
Posted on May 29, 2008
I have a thought. How about drilling a small hole from the back(motor side) of the driver assembly and then push out the bit with a small punch? I have considered this, but I don't know yet if the driver is hardened. If this works, the problem should be solved for all users. Then the remaining isue is finding the proper grease for reassembly
Posted on Nov 19, 2007
SOURCE:
I have a Mkita HP1631 drill but I can not change the bit the chock is stuck
I find hitting the end of the drill bit into the chuck with a hammer releases it and allows you to open the chuch as normal. It does seem strange but it works!
Jul 28, 2018 | Drills
How to remove philips bit stuck in dw054 anvil?
Can you drill a hole in the bit? If so, put a metal screw in the hole and pull that out??
GL,
Td
May 28, 2014 | Dewalt DW056-DW054-DW052 Impact Driver...
Quick change clutch is locked
Push the rubber sleve off the drill bit and up the drill bit then the plastic ring. release the clip around the spindle. Slide the clip and chuck sleve forward and remove the ball sitting in the spindle. You should then be able to pull the bit from the machine. If it does not want to come hold the bit in a vice and tap the spindle off the end of the bit using a suitable punch. Rebuild chuck in reverse.
Jan 29, 2013 | Milwaukee Electric Tool Milwaukee 5359 -...
The chuck wont tighten
Sometimes the chucks jam when opened all the way. A firm hand and a quick **** of the chuck sleve will release it sometimes.
Nov 08, 2012 | Ridgid Factory-Reconditioned ZRR9001 18...
I have drilled a 1 inch hole in my concrete basement wall. I cannot release the bit from the drill. The chuck won't turn by hand to release the bit.
Good Afternoon, Ladooudep55:
I hope you have got your bit back, but if not, remount the drill chuch onto the bit, and drill in forward without pushing the bit. If it still won't move, You can gently wobble the drill to enlarge the hole and retrieve the bit.
The other method is alternating light hammer taps with compressed air. It will make lots of grit dust.
If the hole around the bit is wet, you may have drilled into an iron pipe, if it smells it was the sewer drain. You will have to decide if you want to replace the pipe section or run an epoxy patch once you have retrieved the bit.
Chr
May 01, 2011 | Makita BDF452HW 18V Cordless Lxt Lithium...
Have a screw head stuck in the chuck .. it was a small bit and now wont pull out.... help
Just took apart a DeWalt, the chuck has a left hand scew that holds chuck in place, may be the problem
Jan 20, 2011 | Dewalt DW056 18 Volt Cordless Impact...
How do I remove drill bit from chuck attachment?
pull up (away from tool) on collar where bit enters tool, the bit should slide out easily; if not try tapping firmly (NOT HARD) on the bit with another bit or similiar object before or during pulling collar
Nov 14, 2009 | Electrical Supplies
How do you change the drill bit for a Ryobi?
My husband explained this, via phone ..... made it simple....... grab the silver ring area beneath the black top area where the drill bit is located. Hold the silver area firmly, while you twist the black top. You will see the release, then remove drill bit. Laymen's terms, but it worked!!
Mar 16, 2009 | Ryobi 18v Variable Speed Impact Driver...
Drill bit Stuck (and then broke off)!
Keyless chucks have two parts (see pictures) when the drill is in operation both parts spin. Assuming you put the drill bit in and tightened the keyless chuck by hand, put on a work glove and grasp the part of the chuck at the front of the drill, grasp the other part and twist the front part anti clockwise.
If this does not work you can hold the front of the chuck and reverse the direction of the motor as if you were unscrewing something, then pull the trigger. If your hand does not grasp the chuck tight enough it will slip, hence the glove. If this does not work you may have to hold the front of the chuck in a vice or with caliper pliers and again the pull the trigger with the drill in reverse.
All this depends on what you used to put the drill bit in with your hand tight or held onto it with something else. Whatever was used should be enough to loosen the chuck
Hope this helps.
If it does let fix ya know.
Cheers
Les
Feb 02, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
2,410 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Craig Butler
Craig Butler
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
