Question about Myron & Davis AD-212 Car DVD Player
No sound from car speakers
Dvd plays but there is no sound what channel
Sound only coming from 3 of 6 speakers
A 5.1 sound card will give output in all channels only if the audio being played is also 5.1.
Normally out of 6 Speakers only 2 front and sub woofer will play sound, in case of a DVD or Movie which has 5.1 encoding, all 5 will come alive.
Also, Dolby Prologic II and Dolby Digital will convert a 2 channel input into psudo 5.1 enviornment but Dolby has to be in hardware or speakers or Receiver.
Jan 21, 2014 | Creative Labs MegaWorks THX 550 Computer...
I just bought Creative Inspire M4500 (4.1) speakers. I connected all the four speakers the way they are supposed to. Now I see that only two speakers are working. When I conduct the audio test, all the...
some cd has only 2 channel sound. which is called stereophonic sound. when u play these cds the audio will be heard only on front left & right speakers. in order to get sound in all four speakers u need a 4.1 channel sound dvd/cd. see on the label of cd/dvd if 4.1 ch. sound is recorded on it.
Sep 03, 2011 | Computers & Internet
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
Sound is great unless I'm playing a DVD. When I'm playing a DVD, the music and sound effects are fine, but I have difficulty hearing and understanding the dialog. Any suggestions?
Check your setup for the center channel level, or to see if the center channel speaker is working at all.
Also check the setup in your DVD player to make sure its speaker setup matches what you have.
Feb 14, 2011 | Yamaha RX-V750 Receiver
I am not able to hear the dialog while playing DVDs. The background is great and comes through all 5 speakers, however, to be able to listen to the dialog, I have to switch over to 2-channel or Stereo. ...
Well let me first ask is the center chanel working? or properly hooked up. Cause most of the times when in 5.1 the talking or "dialog" as you put it comes only through the center channel its just kinda how they do it. Listen to see if the center channel is working. if you are unsure try hooking up a speaker that you know works into the center channel speaker output. If no sound comes out then the reciever possible has blown its center channel. Please follow up with a comment and i will be glad to assist you further thanks, Midwes-tek
Sep 17, 2010 | Coby DVD765 Theater System
When I play a DVD in the system I can only get the surround sound out of the speakers but no voices. If I play a CD or hook it up to my tv everything is ok.I have tried a number of DVD's and all have the...
sounds like you need to surround modes. There is usually a Stereo, Dolby, DTS, "virtual surround", 4-speaker mode etc..
When you play a CD or connect to TV it likely defaults to playing stereo or virtual surround.
With real surround, almost all of the voices are coming from the center-channel speaker (normally placed closest to the TV).
Also, check to make sure the center channel is connected properly.
Aug 31, 2009 | Panasonic SC-HT930 System
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Surround sound from Sky +
To upmix 2-channel sound (such as that in a TV broadcast) into 5.1 sound, press AMP and then SUR. DECODE until "PL II Movie" is displayed. This will give you "cinema-like" surround sound from a 2-channel source.
You can also assign this to one of your "Scenes" by following the procedure for scene assignment on page 26 of your manual.
Dec 30, 2007 | Audio Players & Recorders
XO Vision Bluetooth in-dash dvd player
you probably set the audio for 5-channel. In a 5-channel set up. Which it doesnt sound like you have there is a 5th speaker in the center of the dash dedicated for clear vocals. Play with surround options and i'll bet you can fix it
Dec 21, 2007 | XO Vision GX733 7.3 in. Car Monitor
Myron & Davis AD-212 Car DVD Player Logo
16 people viewed this question
Top Myron & Davis Car Audio & Video Experts
xxxxxx xxx
noagge
Tom Chichester
Are you a Myron & Davis Car Audio and Video Expert? Answer questions, earn points and help others
