Question about Frigidaire ATF6000ES Front Load Washer
Washer fills with water then stops
I just moved to a new house and hooked up my washing machine and it won't work. It has power, water supply is on. When I press start, it fills with water, but then it doesn't start the wash cycle. I've tried every option (normal, rinse/spin, heavy, etc.).
  • dbmcnaught May 09, 2009
    The washer is balanced and level, and there's nothing in the bottom of the washer. Any other ideas?
    where would i find switch #17?
    Genius:
  • 1,198 Answers
Http://www.pcappliancerepair.com/model-display.php Check the switch #17 and the hose from it to the tub/pump. I did not see an out of balance switch, but try to get the manual to check for one. It may have been tripped when your machine was moved. I would think re-setting it would be easy.
Posted on May 09, 2009
  • mike kirschbaum
    mike kirschbaum May 09, 2009
    That's the fill switch, it's usually round, up where the other controls are. It may be directly connected to the knob for load size, but on a front loader, there may be no such knob. It will have a small hose going from it to the pump/tub area. Make sure the hose is clear, just blow thru it. If you put a short piece of hose on the switch, you should be able to activate it by blowing hard into it.
  • 98 Answers
2 things make sure the washer is balanced. and make sure theres nothing was stuff in the bottom of the washer when you were moving
  • tony
    tony May 09, 2009
    sorry no clue
  • tony
    tony May 09, 2009
    im not sure and i dont want to tell you something thats wrong
Hot/cold cycle stops before filling up
Your washer has a set amount of time to fill. If the flow is low and the time runs out, then all you will get is the amount of water that was able to fill. Check your lines to be sure that they all fully opened.
Aug 12, 2012 | Admiral 32 cu. ft. Washer
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
When washer fills for wash or rinse it won't stop filling and over flows onto the floor.What do you think it is ?Is it a float problem?
Good luck, i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Roper RAX4232KQ Top Load Washer
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
Washer tub won't stop filling with cold unless tap is off
Sounds like jammed open solonoid valve on hot or cold......water?,,quite simple to fix parts about *£8.00
Nov 02, 2009 | Washing Machines
Moved to new home hooked everything up washer will not fill
ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
Jun 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
F & P GW712 - bowl spins, but won't fill.
Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
Sep 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
this sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Sep 18, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
160 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
