Question about Broan-NuTone Broan Elite E661 Under-the-Cabinet Range Hood
My broan elite e661 lights flicker and sometimes do not work. The fan does the same. Power is good and all snap connects are tight.
3 Suggested Answers
fanny
  • 146 Answers
SOURCE: Broan allure fan and light
Check that you have not accidentaly switched the wall socket off in the cupboard above the rangehood. The slide switch could also be faulty.
Posted on Nov 04, 2007
SOURCE: Broan Allure II
The problem is definetly the control board.
Part# R111638=$110.00. I do service calls for broan.
Inventex.com
Posted on Jun 14, 2008
Light button blinking why
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
Jun 22, 2014 | Broan-NuTone Broan Elite E661...
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
Broan elite hood vent has blinking light that won't reset with power off/on. What gives?
I turned both the light and fan on then pushed the filter button. After a loud beep the filter light reset went off. This worked for me.
Jan 21, 2011 | Broan-NuTone Broan Elite E661...
Broan Fan surging and light flicking on and off
If it is a Florescent light, it may just need replacement. However, if it is a filament light, if it flickers on/off when the fan is active, there could be a wiring problem. But I doubt that...lOL :) It may just need a replacement starter sometimes if its a florescent, the tiny battery like thing that hangs a bit out :)
Apr 05, 2010 | Broan-NuTone (8663RP) Ceiling Fan
I just had a Broan Elite E662 hood installed and it is blowing out instead of pulling air in. I held a tissue up to the filter and it does not pull it up...rather it blows it down. Was something done...
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
Dec 13, 2009 | Broan-NuTone Broan Elite RM605404 Kitchen...
Suddenly the light and the fan quit . Is there a reset
the only "reset" is the circuit breaker.... if they both suddenly quit working, there is no power to the hood at all.... if the breaker/fuse at the box is good, then the hot wire has slipped out of the connection.... not an easy way to trace it. all you can do is work backwards, starting at the power box up inside the hood. if all those connections are tight (power supply to unit's wires) then it's in the wall, attic, or under the floor.... no fun.
Nov 26, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Aug 11, 2009 | Broan-NuTone N-8663RP Combination Light...
Kitchen Ranges Logo
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
