Netgear router wgt624
Get the internet at main pc but neither of my 2 laptops can access it. They see the router but cannot connect. They both worked for the past 2 years????
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on May 10, 2009
My netgear is up and running and all the bars are up and im on it but when i log on too the web it says problem loding page
Netgear WGT624 V3 Wireless Router Problems by BigG2 - January 16, 2007 1:17 AM PST
Hi Guys/Gals,
My wireless connection is not working and i cannot log on to it, I have connected a Netgear WGT624 V3 Wireless Router to my Motorola SurfBoard SB5101E Modem which is connected to Telewest Cable Broadband (internet works fine if i access directly through the modem), on the router the power light is lit and also the internet light flashes rapidly but the wireless light comes on for a couple of
seconds and then goes out - i think this is the problem? I have tried logging on to the router to check the wireless settings but cannot access it, i have also tried connecting directly via LAN but cannot get this to work either although i am not sure if i have connected it correctly?
Any ideas/comments/advice is very much appreciated!!
Thanks in advance,
Jan 05, 2011 | NetGear WGT624 Wireless Router
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
Hi, i have bought this netgear 108mbps wireless router WGT624, 2 weeeks ago, it was working good, but now suddenly it shows less mbps and when tried to restart it, now it not working, i mean it says in my...
I suggest try to check the netgear if it is connected to the internet. If the wirelss signal is good, it might be the internet connection is having some issue.
What you can try to do first is:
1.connect a computer to the netgear directly using an ethernet cable (RJ45)
2. click start then select run type cmd (It's a black screen)
3. type ipconfig/all then press enter on your keyboard
4. check the ip address it should be 192.168.X.X and the default gateway is 192.168.0.1 or 192.168.1.1 depending on the router default ip address
5. on the black screen type ping yahoo.com then enter on the key board
*if there is a "reply from" message it means there is an internet connection going in the router and you need to configure the router. *If the message is "unable to detect" or "request timed out". You need to contact you Internet Service Provider for assistance.
Nov 21, 2009 | NetGear WGT624 Wireless Router
Internet conection via linksys gateway through netgear router
Not totally for sure but i am myself running linksys. if its a new pc you must first configure your settings in order to hook up it up. on ur pc you should have networks first try running a land line to it and see if you can connect if you have multiple routers its very easy to make a mistake with the wiring.
Apr 22, 2009 | Computers & Internet
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Wireless connection
Make sure that your computer is getting a valid IP address from the router. If your wireless network is secured, you might as well consider checking the wireless settings.
Oct 06, 2008 | NetGear WGT624 Wireless Router
NETGEAR WGT624 Router Troubleshooting
Hello!
Inability to access certain websites is due to three main factors.
  1. Security on the web browser is set too high
  2. MTU not set on the router properly
  3. Secured websites
Lowering Down the Security Settings on Internet Explorer
Step 1: Double-click Internet Explorer and click Tools.
Step 2: Select Internet Options, click Security then Custom Level. A window similar to Step 3 will appear.
Step 3: Select Medium-low under the Reset to drop-down menu.
If this did not work, you may try to:
-- enable the MTU on the router.
-- forward port 443 on the router
Apr 24, 2008 | NetGear WGT624 Wireless Router
Issues with Netgear WGT624 v3 Router
Try to put the Internet cable in the Network slot rather than Wireless one.. it will work fine..
Apr 08, 2008 | Computers & Internet
Installed Netgear but can't send e-mail
Ya have to "Open a Port" or "Port Foward" to allow your SMTP and POP3 services to communicate with the Server.. so find out what "Ports" ya need open and using the Admin interface change them to allow your emails to work. This info is generally found in the Manual of the router or online.. And OR your firewall hust be set to pass them on thru too..
Jun 13, 2007 | NetGear WGT624 Wireless Router
Wireless network
Have you looked at these posted solutions? http://www.fixya.com/support/t133938-wireless_connection
Feb 14, 2007 | NetGear WGT624 Wireless Router
Computers & Internet Logo
326 people viewed this question
David Payne
David Payne
