Question about Garmin zumo 550 GPS Receiver
GPS is not getting power on the motorcyclen mount.
Garmin 550 Motorcycle Mount. Not getting power.
  • Anonymous Mar 16, 2014
    montana 650t i want to turn on and off when i start my motorcycle. it is mounted in the garmin mount
Are you firing up the Zumo before you start the bike? I did this and it appeared to continue on battery power when the bike was started - hence, put it in the cradle and it should start up on bike power.
Alternatively, it could be the cradle - I'm on my third in less than a year!
Posted on Aug 24, 2009
Quite possibly the pins that provides power to your Zumo through the mount have corroded after getting wet when the Zumo has been removed. Two ways to prevent this in future, remove the power supply to the mount by unplugging the lead either at the mount or at the battery (or put a switch in) or/and use a product to repel water from the pins on the mount. I remove the mount completely from the bike when not in use which has solved the verdigris problems I was getting.
Posted on Sep 11, 2009
    Problem Solver:
  • 6 Answers
If you're sure the power cord is getting power, then the mount has likely failed. Mine has failed 3 times. Replacing the mount will fix the problem as it did on mine. If the unit is less than 1 year from purchase, Garmin will warranty replace it for free. If not, it'll cost you about $85 plus shipping to put a new one on.
Posted on Aug 12, 2009
Garmin 550t. When i have my zumo on my motorcycle mount it seems not to take power from the bike & then after a while it tells me "low battery", it is wired directly to the bike battery so it should...
Moisture has probably gotten inside the motorcylce cradle through the connector pins. if you take it apart, there is a very small ribbon cable that attaches from the pins to the cicuit board. if moisture gets on the end of the ribbon cable it can short out the small power tracers on the cable and cuircuit board. this happened to me. i had to buy a new cradle. 85.00
May 16, 2010 | Garmin zumo 550 GPS Receiver
Where is GPS power connection on 2007 BMW R1200 RT? I have mount for Garmin Zumo 550. I understand there is a power connector somewhere near the ignition switch, but I can't locate it..
Hi, Dmercier for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Identity source of GPS Power Cord Plug 05 R1200RT
1200 RT gps power connection BMWSportTouring Forums
Bmw r1200rt service manual pdf
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 05, 2009 | 2007 BMW R 1200 RT
How to install Garmin Zumo 660 gps on harley-davidson. It needs to be installed on a 2009 Street Glide FLHX.
The unit comes with a Motorcycle mount with integrated power cable and mounting hardware.
Oct 09, 2009 | Garmin zumo 660 GPS Receiver
Zumo 550 no sound in car mount
From the main screen, choose the wrench icon, then select the screen icon for the speakers and make sure the sound is all the way up.
Jul 03, 2009 | Garmin zumo 550 GPS Receiver
I press the power button, the screen appears, 2 secondes later, it shuts down.
If the battery is depleted and it's not in a powered mount, that will happen. Recharge the unit via the USB cable if necessary and make sure the battery is charged at least 4 hours before re-attempting.
Apr 26, 2009 | Garmin zumo 550 GPS Receiver
Zumo Wull not charge form bike mount
Experience the same problem with my Zumo 550. Told by service advisor @ Radio World that this is a common problem. Unit needs to be charged on the DC charger occasionally. The motorcycle mount and car mounts, I was told, does not charge the battery on these units, but maintains a charged battery.
Oct 19, 2008 | Garmin zumo 550 GPS Receiver
Zumo 400
You mean helmet speakers? If you use the bike mount it should work, the car mount is a line out(not amplified so the sound is very poor) I had a wired helmet set, worked okay below 50 KMh
Jun 16, 2008 | Garmin zumo 550 GPS Receiver
Gps c330 motorcycle mount
Ram makes a handlebar mount that is available on Ebay specifically for the C330, search "c330 motorcycle" or there is a guy I just read that has used the suction cup mount to his tank. He says it works great! I am going to try it out.
Mar 12, 2008 | GPS
Fitting zumo 550 to ducati st4s
RAM mount (http://www.ram-mount.com/gps_mounts/model_garmin_gps_mount.htm)
Dec 09, 2007 | Garmin zumo 550 GPS Receiver
Unit won't draw power from the bike battery
Ay I just fixed my Zumo 550, that would constantly go into battery power when hook up to my Motorcycle, found the enemy I was fighting was lack of proper ground (-).
Aug 20, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
406 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
