Question about SanDisk Sansa m250 MP3 Player
Won't come on
A friend gave this to me and I was told to replace the battary and it would work. I've done that and it still doesn't work.  Any ideas?
  • kathys Jan 13, 2008
    I also have that problem but I am unable to find a file name with Sansa in my documents so I am unable to do a hard reset. Any other suggestions?
    Problem Solver:
  • 7 Answers
To do a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players.
Posted on Jan 10, 2008
  • gimpiesatty Jan 10, 2008
    In step 1, remember to reinsert the battery. You do not need to press any buttons when you plug the Sansa into your computer.
It could be the classic lockup that these players are famous for but usually they botup to the sandisk screen and then its a brick, anyway try a total hardware reset by:
1 taking out the battery.
2 holding the powerbutton down for 40 seconds
3 waiting 5 minutes before putting in a fresh battery and starting over.
Posted on Oct 26, 2007
SOURCE:
Toshiba Satelite laptop won't turn on ?
take it back and use the warranty or contact the manufacturer if you've been there 6 times then the seller should replace it.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 09, 2012 | Computers & Internet
Coffee bean light won't go out when full and coffee won't work
Hi coffee friend I have just answered this question. I think
After you have done all the cleaning you have done, you can try this: do check that all knobs correctly set. That the steam spout is closed. that the water tank sitter correctly
Disconnect from power, wait 2-3minutes connect again and hope for the best.
Kolbrun
Apr 16, 2012 | Solis Palazzo Espresso Machine
Ok, I have a Zhone 6211-I3-200 Bridge/Router or in other words a Paradyne ADSL CPE, and I cannot for the life of me get it to work with my Xbox 360. I used to have a different router and I would switch...
Zhone Modem Model #. 6211-13-200-0PA ADSL2 BRIDGE/ROUTER, AN.
I would like to upgrade current Firmware, but it is quite difficult and my ISP support even knows how to do this upgrade.
Nov 06, 2011 | Zhone 6211-I3-200 Router
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
I have a 2002 Buick Rendevzeous. Sometimes the driver side low beam works, sometimes it doesn't. When it doesn't, the turn signal won't blink. It just stays dimmly lit. Right now, the low beam...
You have a bad electrical connection. Check the wiring harness and both sides of it's connectors for corrosion and or breakage. The connector terminals will become worn and corroded and the wiring sheaths a prone to weathering and become brittle. Replace or clean as needed.
Sep 04, 2011 | 2002 Buick Rendezvous
I need to replace the brake pads on a friend's mercury sable gs (2000) but he doesn't have a Haynes or Chiltons for it. It's been a while since I've done a brake job and am curious if there...
There is no need to bleed the brakes unless you get air in them. Just removing the pads and pressing the cylinder back in won't let air in. If you are doing rear disc brakes the cylinder on those has to be screwed back in. I've been able to do it in the past by using a pair of pliers to rotate the cylinder but they do make a special tool you can pick up at a part store for this purpose.
Aug 09, 2011 | 2000 Mercury Sable
SanDisk Sansa m250 MP3 Player Logo
269 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
