Question about Moultrie Cameras
Set date and time on a moultrie lx501r camera
4 Suggested Answers
  • 374 Answers
SOURCE: set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Posted on Mar 30, 2008
  • 296 Answers
SOURCE: how to set the time and date
Looking at front (inside of outer door) the D-40 has very different look than my I-40s and 60s, but bet programming is near the same.
1st, turn red arrow switch to"setup";press select button until time/date appear,here, not sure of programing...pressing select at this point may take you out of time setup mode.Try the up/down buttons below the display once right time is displayed, press select.
Hope this works, and good luck.
Posted on Feb 20, 2010
  • 244 Answers
SOURCE: says date/time not set but wont let me set the time or date!
Broken keypad ribbon. It's because the keypad ribbon is folded over twice and the creases split over time. have a look at my tips page for this problem. It won't help you much I know and the only solution is a replacement membrane.
Posted on May 04, 2010
Flash doesnt work
Check your settings on camera. Go the mode button it will show time and date hit the down arrow key until you get to Time duration make sure it's not set to all day if its go to default settings hit the enter button then hit the up arrow key then hit enter. Test camera in dark area for about 3-4 pic if still not working. Call Moultrie 8006533334 option 1 and 1 for a live person.
Dec 30, 2013 | Moultrie Game Spy M-880
Date time displayed wrong but programmed right
Has this to do with difference in europeen and american time and date?
Like europ: DD/MM/YY
american: MM/DD/YY
europ has 24 hours clock america 12 hours with AM and PM.
Nov 03, 2013 | Moultrie Game Spy D555i Trail Camera
MGC-12592 d-555i. The unit turned on I changed the date and time set the capture for 10 seconds. The red light blinked when I walked by, I did not see the flash work though. I can't get photos to download...
The red light is the infrared, this is not a white flash camera you can view pic on that camera by going to playback. How to get there hit your menu button go to camera setup and then go to playback and hit enter you should see them then. If still not working call Moultrie 8006533334 option 1 and 1 for a live person will need equipment to troubleshoot the issue.
Sep 01, 2013 | Moultrie Game Spy D555i Trail Camera
I have a Moultrie IR6 model DSG-160 that worked fine when I placed it this year. I go out to check it, and now the display only partially works. Not enough to read. Thru much back and forth to the...
www.moultriefeeders.com and ask for replacement LCD menu display...$14.99...they send instructions to replace...I get my parts from other defective cams.
Sep 06, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I have a Moultrie 4.0 game camera. The only thing I can get to come on is the Laser Aim to come. What can i do? I can't even get date time or anything to come. Is this junk or what?
to get the date and time turn it on and then use the up and down arrow keys to set date and time., press the mode button to have the auto handheld shooting mode.select auto, this will automatically detect animals or whatnot. the green lcd light will flash for 30 seconds and then its armed and ready..to use as a hand held just to take pics put the setting on handhead. good luck
Nov 30, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
How to set the time and date
I have read through the manual and could not find any special action required the register the change.
The only thing that I can think of is, did you continue to press the "select" button until you have left the time set routine? If you do not exit the routine then it seems likely that changes will not be recorded.
Sep 17, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I-40 camera will not go to picture mode and start taking pictures
Have you done the time/date setup? Online manual says it goes auto after 4 minutes, but perhaps the date/time need to be setup first? Online manual here in case you lost your book :)
http://images.ebsco.com/pob/moultrie/catalog/dgs-i40-user-manual-compressed.pdf
be patient, it takes a bit to load
Aug 26, 2009 | Moultrie MFH-DGS-200 Digital Camera
Locked up
On my Moultrie MFG-DGW 2.1, I was unable to change settings etc... It seemed to be locked at the Date/Time screen. I powered off the unit, removed the memory card. Turned on the unit. Then I could change the settings. I made my changes, powered the unit off, reinserted the memory card, turned the unit back on and it read the card and I could make changes too. This happens from time to time. I just have to follow those steps to clear it.
Hope that helps.
Oct 28, 2008 | Moultrie MFH-DGS-100V2 Digital Camera
Moultrie MFH-DGW 2.1
Get it at
http://images.ebsco.com/pob/moultrie/catalog/GameSpy100V2Manual.pdf
Sep 13, 2007 | Moultrie MFH-DGS-100 Digital Camera
Cameras Logo
88 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
