Question about Gemini DJ G4V - Gemini G4v 4 Channel Virtual Dj Controller
Controller does not light up
Panel activates and appears to work properly but none of the led lighting works on the device.
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
How do I fix a Canon pixma ip6600D printer?
ALARM LIGHT which always glows - RAM error (logic board is dead)
Apr 02, 2015 | Canon Pixma iP6600D InkJet Photo Printer
Sharp Aquos LC-C3237U no picture backlight OK green light on
check if their is a signal on voltages around 3.3v at the inverter board if none their is a problem in the board which is in the processor.
Aug 30, 2012 | Sharp Aquos Televison & Video
LIGHT
If the light is not working it can be a hardware issue as the power to the LED's are not active or switched on by the controller.
You can remove the main panel and check for moisture , if so dry , check for any dry soldering of the board and reset.
Sep 28, 2010 | Nokia e65 Cellular Phone
Lexmark 2600 wil not turn on, no lights, nothing absolutely zippo. Definately has power from the mains switch so could be either the transformer into the printer or within the printer itself. have tried...
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave power cord attached to the power adapter and the other end of the power cord plugged in straight to a known working wall power outlet, bypass any surge device or power strips. There should be green LED light on around the power adapter's silver contacts. If none, make sure the power cord is properly secured. If that doesn't help, that's the main problem. If LED light is on, plug it back in the printer in the right position and properly secure it in. If printer won't automatically power on, press the power button. If that won't help at all, the printer itself is the problem. I hope I can assist you more on this.
Jun 28, 2010 | Lexmark X2600 InkJet Printer
Xbox 360 controller not working, all 4 lights are blinking.
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console:
First, Press and hold down the Guide Button on the wireless controller until it turns on.
Second, Press and release the power button to turn the console on.
Third, Press and release the connect button on the console.
Fourth, Press and release the connect button on the controller.
Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
Jun 06, 2010 | Microsoft Xbox 360 Controller
I have the Dell 5650 Computer Speakers and first 2 of the speakers stopped working and when i reinstalled the speakers again none of them worked. the green light of the center doesn even light up, any...
Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the “Audio Drivers” Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel.
Scroll to find, "Ease of Access (or) Speech Recognition Options. Click, on" Replace sound with visual cues."
In the See also: (Category), click, on “Audio Devices, and Sound Themes” click, “Playback” Next, click on the Active "Speakers.” Click “Configure” to "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced),“not recommended!” In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: Click "OK" to all change; 'Save' and Apply!, before exiting. “Did this solution help?”
Feb 03, 2010 | Dell 5650 Computer Speakers
Wifi isnt working the lights not on what do i do
See to it that your Wireless LAN is installed in your LAPTOP correctly, at this point if your LAPTOP have Wireless LAN and not installed properly cannot connect to the network & even your network icons does not appear, its useless.
Go to your Control Panel and and select icon SYSTEM then go to DEVICE MANAGER, you can see their your WIRELESS LAN device is working properly and if not install it using your Utility Disc of your LAPTOP, hope this might help you, good luck!
Jul 29, 2009 | Toshiba Satellite A15-S127 Notebook
HP laser Jet 2420
cannot print to the printer server
Jul 04, 2008 | HP LaserJet 2420 Printer
Gemini DJ G4V - Gemini G4v 4 Channel Virtual Dj Controller Logo
51 people viewed this question
Top Gemini DJ Audio Players & Recorders Experts
chuck ringwood
chuck ringwood
James Kovacs
James Kovacs
T-Comtech Repairs
T-Comtech Repairs
Are you a Gemini DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
