Question about Water Heaters
Descaling a insinkerator
Hot tap has gone very slow plenty of cold pressure but after heater unit is very slow have replaced filter made no differance
hessmar
  • 5 Answers
SOURCE: InSinkErator Instant Hot Water Faucet leaking
Make sure that there is no leaks traveling down the hoses or at the connections on the top. The tanks can leak, if you have the Stainless Steel tank the following information applies - Stainless Steel Tank: 3 years, with an extended service plan available when installed by an InSinkErator Pro Circle™ plumber. I you product is under warranty I believe that you can call the number that is printed on the tank and literature.
Posted on Dec 06, 2008
CRTN
  • 716 Answers
SOURCE: No water flow from hot water tap with a rinnai tankless water hea
Its A Possibility The Left Over Water In The Hot Is Frozen. If Your Line Is Exposed Outside Somewhere It Can Easily Freeze Up. Turn On The Hot Water Everywhere In The House And If Accessible Check The Lines To See Where The Warmth Ends. You Can Leave One Off Over Night In Hopes That It Will Eventually Defrost.
Posted on Jan 16, 2009
  • 659 Answers
SOURCE: Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Posted on Mar 31, 2009
  • 659 Answers
SOURCE: insinkerator hot water heater takes a long time to dispense water
It may have mineral deposit buildup on the inside. You will need to consult your maintenance manual to see how to flush the unit and clear it of deposits. You can also contact Insinkerator for the information as well. You can use vinegar to clean it just like you would a coffee pot. Take the inlet supply off and using a funnel pour the vinegar in and turn the unit on.
Posted on Apr 03, 2009
gary1121
  • 332 Answers
SOURCE: How to replace heating element for InSinkErator W154 water heater
take the front cover off, it is just snaped on, there you will see it, depending on the age of the unit insinkerator will replace it for free, you just have to install it, but for the most part it might be cheaper to change the unit
Posted on May 30, 2009
Instant hot water tap - hot steam but delay and no hot water
This unit is set way too hot. The steam is pressuring the water out of the unit.
Feb 18, 2014 | Emerson InSinkErator C1300 Chrome...
I have an insinkerator hot water dispenser with stainless steel tank, and the tank is now leaking. I'm wondering if it can be fixed or needs to be replaced
Replace water heater if tank wall is leaking.
These things have short warranty period.
Stainless steel will theoretically last longer, but steel tank water heaters have replaceable anode rod to prevent rust-out.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Be sure to recycle the old metal.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Oct 29, 2012 | Emerson InSinkErator C1300 Chrome...
No water being dispensed from my Insinkerator hot water tap following insallation of new filter
Probably debris from old filter got trapped in the line.
If the insinkerator has aerator, take that off and flush out debris.
Otherwise, the line will have to be taken apart and blown out.
Aug 11, 2012 | Water Heaters
Water temp. at the tap fluctuates
It is likely the inlet filter is plugged. this reduces the flow and then the heater adjusts the burn rate down to protect itself. the filter screens are small and plug easily. It would be a good idea to install a larger pre filter on these heaters.
May 30, 2010 | Bosch 2700ES Natural Gas AquaStar ...
Noritz tank less propane water heater, no out going pressure
There's a filter on the cold water side of the unit. You'll notice a black, plastic, cylindrical component directly below the unit on the cold water line pointing to the left. If you shut of your water and unscrew that cap, there will be a filter attached to the other end.
If the filter is clean, I'd recommend calling tech support for help. You might have an error code.
Jan 08, 2010 | Noritz Liquid Propane Tankless Water...
Brownish water from insinkerator
sometimes with well supply you are better to have two filters one outside easy access then another as supply enters your property best of luck
Nov 02, 2009 | Emerson InSinkErator - Water Heater - W152...
Insinkerator hot water heater takes a long time to dispense water
Apr 03, 2009 | Emerson InSinkErator C1300 Chrome...
Under sink water heater no flow of hot water from it
basically the principle of the heater is water flows into a internal tank and is heated by an element. You open a hot tap and the mains cold water forces the hot out and replaces it inside the heater.As you have a flow problem i can only suggest you may have some kind of restriction or blockage in the cold water supply at the water heater or from the hot supply from the heater.If you live in an area where lime content is high then this can calcify when heated.If you can, isolate the water supply and electrical supply and check the pipework for blockage.Also investigate your hot tap as this may be the fault. Good Luck
Mar 26, 2009 | Water Heaters
Water Heaters Logo
331 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
