Question about Frigidaire FAH085N1T Air Conditioner
I have a Samsung AQV24JAX Split-type air cond unit. AC is great in summer; but heating is a problem in winter; if temp gets below 25 them feels like it blows cool air, not warm! In NC so temp doesn't get below 25 very often, but when it does not comfortable with this unit. What is the fix?
SOURCE: No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Posted on Jun 29, 2008
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
SOURCE: AC not cooling enough
Probably low on refrigerant, if valve moves when heated it is working, assuming the system is matched.
Matt
Posted on Jul 01, 2008
  • 534 Answers
SOURCE: Blowing cold air instead of the heat
Heater coil has possibly burnt out. his coil is located rightr behing the front coil of the a/c You need to pull the unit from its sleeve and look inside behind the a/c coil and there it is. It looks like the inside of a toaster the elements should be incased in a metal box. What causes the burn out is 1 poor air flow over coils due to dirty filter or dirty coil, 2 dust build up, the minute particals the get through the unit 's filter and build up over time causing burnout, 3 possible high limit switch on the coil housing itself. This switch prevents the heater from overheating and causing a fire. Have this look at by a tech the cost incurred isn't really that much.
Good luck on your repair hope this helped
Dave
Posted on Dec 11, 2009
  • 45 Answers
SOURCE: my ac is not blowing cold air
The unit may be low on refrigerant. There is probably a low pressure switch in the unit to protect the compressor so it wont turn on and get damaged beyond repair. You can take it to your local appliance repair shop and have it looked at. I would get a quote on repair first. Most of the time it is cheaper to buy a new unit than it is to pay just the labor to have it repaired.
Posted on Jun 07, 2010
How do I replace the heating elembent in a frigidaire FRAM18ER2A ac/heating UNIT
This type of unit does not normally have a heating element, it is a heat pump. In summer if blows cold air through the front and hot air out of the vent at the back. In winter, cool air is drawn in through the back, heated by the compressor and vented out of the front vents.
The manual is here. It seems Frigidaire Service is the only answer.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020219A0576en.pdf
Wiring diagram is here. The unmarked item, 2/3rds down on the left may be an element.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/202021990031.pdf
This intimates it has a 4000 watt to 4900 watt element depending on voltage supply.
Voltage Rating: 240V / 208V 60Hz
Amps (Cool): 8.4 / 9.2
Watts (Cool): 1900 / 1880
Amps (Heat): 22.2 / 20.0
Watts (Heat): 4900 / 4000
Horsepower (Cool): 2.49
Power Cord Length: 5' (6')
Plug Type: 6-30P
Despite my best searches I can't find anyone selling gthe element. Try these two companies though
Frigidaire Refrigerator Heating Element Parts: Fast Shipping
https://www.repairclinic.com/Shop-For.../Frigidaire-Refrigerator-Heating-Element-Par...
Looking for parts for your Frigidaire Refrigerator? ... Frigidaire Refrigerator Garage Heater Kit. ... Frigidaire Refrigerator Defrost Heater Assembly.
Missing: fam18er2a
Frigidaire 137488301 Heating Element (10 - AppliancePartsPros.com
www.appliancepartspros.com › Frigidaire › Washer › Frigidaire Washer Parts
US$65.40
HEATING ELEMENT (10 137488301 / AP5618485 made by Frigidaire.
Missing: fam18er2a
Nov 16, 2017 | Frigidaire Heating & Cooling
Heat and ac stopped working in 05 kia sedona
check that the heater control (tap ) is being turned on by the controls.. Have an accredited ac mechanic check the ac system .
Jan 07, 2014 | 2005 Kia Sedona LX
I have lost the manual for my fujita 2.5 split system and all i want is w what to press on the remote control..... as from Winter to summer Cheers Clare
You decide what temp you need.
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Jan 06, 2011 | Heating & Cooling
Hi I have an Amcoraire aos121hx mini split, it worked great last summer and this past winter. Haven't used it for a few months and now when I try to get cold or heat it gives a P8 error?
Check the gas pressure by depressing the Schroeder valve under the cap where the gas pipes enter the outdoor unit. you have probably lost some or all of your gas
Apr 21, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
No AC from older Intertherm split system
It sounds like you are low on refridgerant. Double check to make sure both fans and the compressor are running. If so then you have a refridgerant problem.
Aug 29, 2009 | Heating & Cooling
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
Nov 24, 2008 | GE Zoneline AZ38H12DAD Split System Air...
AC WON'T COOL
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Frigidaire FAH085N1T Air Conditioner Logo
77 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
