Question about Huffy 26in Ladies Sante Fe Cruiser Bike - Blue
I am needing a manuel on how to put a 10 speed 26in girls bicycle together it is about a 1977
  • 200 Answers
Rear wheel should be already on, put front wheel into forks and tighten nuts or quick release lever.
The handlebars should alredy be attchd to the neck. Put the neck into the frame and tighten bolt or allen head when bars are straight aligned to front wheel. Install seat and any reflectors....follow these instructions carefully cause the manual that comes w/these bikes is junk....Good Luck to you friend.....Tim
Posted on May 10, 2009
Value of Schwinn bike #S4973TGA
Value is dependent on type of bike (esp. # of speeds), equipment level and mechanical/paint condition. Check Craigslist for similar bikes. Serial number is not helpful - need model of bike.
How to determine the year value etc of your bicycle
Apr 04, 2016 | Schwinn Cycling
I have a question about putting together a disney princess 12in bike, I put the handle bars in, but they don't seem to attch to anything. And the owners manuel is for multiple different bikes, so it is not...
If I understand your question, you put the handlebars into the front steering assembly but they don't attach.
On top of the handle bar is a screw that when it is turned in pulls a wedge shaped bottom piece up. When this is done once the handlebars are in the steering unit, the handlebars lock up and can't rotate or pull out.
If that doesn't answer your question, let us know.
Gary
Dec 21, 2010 | Huffy 12 in. Girls Disney Princess Single...
I have a problem with a huffy 12 in. girls dora the
Sounds like the valve stem you may need a tube if you bought it new or recently new take it back??Hope this helps?
Oct 11, 2009 | Huffy 10 In. Girls Dora The Explorer...
I need instructions on when to change gears on a 15 speed, 24'' girls bike. I bought it second hand, and have no idea which gears to use when.
biggest in the back and smallest in the front gives you the fastest accel and is used for uphill as well.. smallest back and biggest front is used for top speed....
Aug 18, 2009 | Huffy Alpine 26 Women's All Terrain...
Cant get rear hub back together
Try going to www.sheldonbrown.com/repair/index.html. I think what you need is there. Hope this helps.
May 20, 2009 | Schwinn 20 Inch Girls Starlet Bike
How to put a chain on?
Your question is not entirely clear. If you are trying to replace your existing chain with a new one, then you will need a special tool (chain breaker) to remove it. Here is a link to a video on how to do it.
You may also want to consider getting a quick release chain link for the future to make the job easier.
If you done have access to a chain breaker, then I suggest you take the bike to a bike store. Replacing a chain is cheap and can be done fast.
May 06, 2009 | Huffy 26in Mens Sante Fe Cruiser Bike -...
How to assemble the front tire to hannah montana 20 in. bike
hi,
When you try to put the wheel in, is it getting caught on the brake, if it is, the brake caliper unhooks from the cable
Are the forks bent, you can tell because if one of the fork legs line up with one side but not the other then the chance are that the forks have been bent somehow.
Dec 25, 2008 | Disney Hannah Montana 20-Inch Girls...
Huffy 26in Ladies Sante Fe Cruiser Bike - Blue Logo
170 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
