Question about APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System
APC BX800 cycles betweeen on line and battery
The APC UPS BX800 cycles between "on line" and "battery" every few seconds. Batteries are new.
IB4G2008
  • 3587 Answers
SOURCE: APC Smart-UPS 1500VA
yeppers...those APC units sometimes kick the monitoring software. sometimes you need to unhook the connection cables(like a reset) so that the firmware can 'unlock' which can cause that christmas tree effect on the panel lights.
Posted on Feb 06, 2008
  • 55 Answers
SOURCE: APC Smart UPS 1500 will not start.
It could be that the cable to the front-panel got damaged during the battery replacement.  After all these years you would think APC would improve that aspect of their design.  All I can suggest is inspecting the cable and where it connects to the front panel.
Posted on Apr 26, 2009
  • 25 Answers
SOURCE: APC BR800 Overload light with beeps
Your main control board is defective, you need a new unit.
Posted on Jul 11, 2009
jvpacoin
  • 91 Answers
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Posted on Aug 14, 2009
  • 59 Answers
SOURCE: APC SMARTUPS 1500VA Battery Problem When Replaced
You are correct. The APC Smart line has a partial charge when it's new. Similar to cordless phones, the work right away, but you're still supposed to charge them before use for best results.
Just leave it plugged in with no load for a couple hours and it will be fine.
Posted on Sep 23, 2009
30kva apc ups VT is nor getting On?
Try holding the "on" button for a few seconds until magnetic relay is on.
Sometimes flat(dead) batteries will stop UPS on
Apr 19, 2014 | APC Smart-UPS 2200XL (APCSMART2200XL) UPS...
My apc ups 880va is not working online .what is the problem?
Have you change the battery? most APC ups just need to change the battery for it to work again.
Jan 20, 2013 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
Apc xs800 new batteries
I Bought two RBC32's and had to hook them up to the connector and did it wrong on the first try. Make sure you connect the yellow to the Red terminal on one battery and the Black on the other, then connet the remaining red to red on one and black to black to the other. Once I did that and plugged it back in everything worked fine.
Apr 06, 2012 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
What is startup procedure after replacing batteries?
This just means to reboot or turn your apc ups system off and then on.
If it tells you anything else accept from that like how to do it exactly than please reform me.
PCHELPSTER007 from youtube
Jul 05, 2011 | APC (BX800) UPS System
Where can I get schematic for this unit?
Apperently APC has a policy against releasing schematics
Read
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | APC Smart-UPS DP 6000 UPS System
We have a APC Smart UPS 2200XL. We had a power failure last night and now all six lights in the front (AVR Trim, On Line, AVR boost, Overload, On Battery, and replace battery) are flashing at the same...
The light pattern indicates the batteries need to be replaced. The typical life of UPS batteries is 2.5 years, after this time the cells will not hold the proper charge. When your power when off last night the UPS would have tried to switch to battery power but it most likely failed after just a few minutes as the batteries shorted. The UPS has a protection circuit that prevents it from starting up properly with dead batteries so you get the flashing lights and the unit shuts off. The batteries are available in most cities from car battery dealers, not like Wal-mart but battery only dealers, just look in the yellow pages for batteries. You can take the old batteries out of the unit by removing the front panel and unscrewing the metal plate just behind the front cover. The old batteries are connected with a wiring harness that plugs in. Just bring the old batteries to the dealer so they can get you the correct replacement part. The new ones should be less than $100 so it is well worth the price compared to a new unit.
I hope this helps, if so please rate our solution.
BuddyMc
Feb 04, 2011 | APC Smart-UPS 2200XL (APCSMART2200XL) UPS...
Smart apc ups error with all indicator flashing .
APC Smart-UPS 1500VA has an error. All it's pannel lights blinking. what is the best possible solution to this?
Jun 14, 2010 | APC Smart-UPS 1500VA Shipboard...
The 'ON BATTERY' light goes on every so often and the unit beeps. Very annoying as this is not an overload so I want it silent.
Hello.
There might be several reasons for this:
1) Malfunction of your UPS' circuit
2) Damaged wire cord
3) The power on your wall socket fails too often
4) Most likely the batteries are exhausted. See the UPS' manual about batteries replacement.
Good luck
Jan 24, 2010 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
My apc keeps clicking and the on line and on battery lights keep blinking
Often, it is an expired battery that will cause an issue like this. Since a bad battery renders the APC ups useless, it will usually display blinking lights to let you know that something is wrong. The software, if installed, will also help troubleshoot the problem. You find which battery you need from this site: http://batteryinternational.com/ups-batteries-apc-batteries.html
Aug 28, 2009 | APC Back-UPSĀ® XS 900 (BX900R) UPS System
APC back-ups XS 800 battery backup : warning
Turn it off and unplug it from the wall.
Open it up and make sure that the red and black wires are connected.
If they are the battery needs to be replaced. They are only good for 2-3 years. If you are not comfortable with my instructions, call APC for free support. (800) 555-2725
Vote for this solution if it helps.
Aug 15, 2009 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System Logo
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
