Question about RTO Bodyguard T200 Treadmill
Belt shifting/crooked and frayed on Proform 725 TL
Hello...I just bought a used treadmill: Proform 725 TL...the belt is shifted to the right at the bottom (it is actually crooked on alignment - not straight on the rollers) and there is fraying on the left side - whole belt...I can walk manually to move belt away from roller edges, but it just goes right back to original crooked place. there is nothing in the manual regarding fixing ....it actually says not to lubricate belt or platform, although it looks like oil has been applied at some point somewhere, as there are 'blobs' soaked on to the belt 'joint'...additionally, there is a half circle piece of plastic broken away from the roller casing (rear roller cover, where roller pin enters) - is this a problem?..it does not look as though it hinders performance at all, but again, I know nothing about this!...any feedback would be greatly appreciated!...thanks so much!
  • Anonymous May 17, 2009
    This has just happened to me but I cant seem to get the left side roller back in place. I have searched on line to find a rear roller cover but no one seems to recognize the original part number of 132218 - it is number 82 in the original manual.
    JS.
In the back of the manual, it describes the adjustment for this. on the end of the platform (near where your belt is crooked) there is a hex nut. the manual says to turn the machine off before adjusting, i find it is much easier to do while the tread is still moving. turn it about a quarter or half turn one way or the other until the tread is aligned.
Posted on Jun 29, 2009
ProForm 380i Treadmill: How to repair frayed edge of Walking Belt
Discription: WALKING BELT W/FASTENERS, Part # 193575, Model # PCTL49820, Price $48.83
In humble opinion you should replace the part, it sounds like an accident waiting to happen Call Icon Fitness @ 800-999-3756 and give them the info above.
Jul 18, 2010 | Proform 380 Treadmill Walking Belt
My belt is over to one side to much is there and easy way to get it back in the middle
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Jul 16, 2010 | Proform Quick Burn Pro Treadmill with 12...
Belt is off alignment
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 31, 2010 | Proform 730 Folding Treadmill Model...
I have a Proform 380 Treadmill. When the treadmill is on the belt rubs on the left side.How do I center the belt?
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 24, 2010 | Proform 380 CS Treadmill !
How do you adjust a belt on a Proform 385X. It is
If the walking belt is off-center, first remove the keyand UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 17, 2010 | Proform Exercise & Fitness
The belt keeps going to one side+ rubbing,, is there anyone that
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes.
May 14, 2010 | Proform 6.5q Treadmill Walking Belt
The belt seems to slide to one side on my Proform Crosswalk 380. How do I fix it?
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Feb 27, 2010 | Proform 380 CS Treadmill !
HOW DO YOU ADJUST THE BELT ON A PROFORM 725 SPACE SAVER PERSONAL TRAINER TREADMILL. IT MOVES FROM SIDE TO SIDE AND IS FRAYING AT THE EDGE. DO YOU ACCESS THE ADJUSTMENT IN THE FRONT OR THE BACK OF THE...
Use the allen wrench to loosen side that is touching. 1st locate on the end of the treadmill 2 slots, 1 on each side and place the allen wrench into the slot. turn anticlock wise 1/4 turn. Turn on treadmill at 3 to 4 miles per hour (not standing on it) and make ajustments in 1/4 turns until belt gets centered and snug. When you have it centered you may ahve to tighten or loosen it in case it is slipping when you are running on it. When you ajust it when centered you should do this in 1/4 turns on both sides to keep it centered. If this doesnt fix the problem I suggest that you may have some other problem or are not capable of reolving this problem on your own. Ask another friend for there opinion if this fails.
Feb 19, 2010 | Proform 730 Folding Treadmill Model...
Our Proform 585TL's belt has shifted to the left and it starting to fray. We can physically move it back to center, but as soon as we start the belt again is moves back to the left. Any suggestions?
There's a hex screw at the back of the deck, just to the left of the belt. Turning this screw one way or the other will change the angle of the roller. If the roller isn't at the correct angle, the belt moves over either to the left or the right.
Apr 05, 2009 | Exercise & Fitness
RTO Bodyguard T200 Treadmill Logo
2,112 people viewed this question
Top RTO Exercise & Fitness Experts
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
