Question about Orion Televison & Video
Orion sled 2468w reprogrmaing
I have xfinity and we have the box but every time we hook it up it doesnt come threw on the tv how do i reprogram the tv so that i can get a signal i also have it on cable
MikeNJ1964
  • 398 Answers
SOURCE: orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Posted on Jul 29, 2007
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
Posted on Jun 09, 2008
ronpar
  • 27 Answers
SOURCE: orion tv only has 2 channels and it's hooked up to cable
go to menu,go to were it says cable and air,select cable. then go up to auto program do search, this should do what you want.
Posted on Jun 13, 2008
  • 520 Answers
SOURCE: Orion and TV Converter box
Most converter boxes will hook up to your tv if it has an antenna jack. I'm guessing the list you were looking at was a list of converter boxes that could be purchased with the governments coupons, not a list of tv's. I hope this is helpful to you. Make sure the converter box you buy has coaxial out to tv jack(it will look like the ant in jack).
Posted on Apr 17, 2009
SOURCE: connection for digital signal box
You'll need a coax to twin lead transformer that you can buy from Radio Shack.
Posted on Jul 04, 2009
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
Apr 26, 2017 | Televison & Video
How do I hook up tivo,Vizio,Xfinity together?
You need a cable box from xfinity that does not have a DVR built in and then you need to see whether the Tivo can control it. You will need an ir blaster cable from here:
www.weaknees.com/tivo-cables.php
Then connect the Tivo to the cable box and the TiVo to the TV.
Nov 06, 2013 | Televison & Video
Orion SLED 1945
I have plugged in my Orion TV. It brings up a dark blue screen, no picture and will not respond to the remote that came with it or the buttons on the tv itself. I've tried all that was recommended in the troubleshooting section of the guide it came with. Any suggestions?
Aug 28, 2013 | Orion Televison & Video
Orion remote won't turn TV on
You have to setup the DVD by its setup codes with Xfinity. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter" Setup code list, and setup proceedings to Xfinity remote control is given in detail.
Apr 14, 2013 | RCA RCU300WBL Remote Control
Why does my cable box constantly freeze up when I am watching television shows?
In todays cable industry clean RF is a must. However that issue can be lose fittings at the wall or set top box or most especially at the modem. A modem constantly chatters back to the server even when your not using it. A lose fitting there can cause you and the whole neighborhood issues. Try that tighten all your cable fittings all around your house if that doesnt fix it the issue could be a bad box or not even at your home. The other issue often is squirrels chewing on the drop lines at the pole.
Mar 01, 2012 | Comcast XFINITY
Apr 16, 2009 | Orion1934 19" TV
Remote no longer works-need code to reprogram it
the only codes i have are 0121 0135 or 0035
Mar 23, 2009 | Orion1934 19" TV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Feb 22, 2008 | Televison & Video
Jul 29, 2007 | Orion1934 19" TV
Televison & Video Logo
53 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
