Question about Parasound Audio Players & Recorders
Parasound R/HD 300 II IS IT VERY OLD - Parasound Audio Players & Recorders
Why does my parasound a21 shuts off intermitently during play
check for heating is device geting very heat if yes then you chould check heatshink
May 18, 2012 | Parasound A 21 Amplifier
CANNOT INSTALL THE EPSON LQ 300+DOT MATRIX PRINTER ON THE WINDOWS 7 NEW PC
Epson LQ 300 does not have Win7 latest driver. Please use your old PC (xp or visita) to continue with the Epson.
Aug 28, 2011 | Epson Dot Matrix LQ-300+II Printer
Please assist to instal lq-300+ii in dell tm (r) i3 window 7
hello
this printer is too old for Windows 7 -- not compatible
here is the link for the driver , but it is compatibke with Win 98, 95 and 3.1 only
http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14311&prodoid=8241&infoType=Downloads&platform=Windows
i hope i served you well
Nov 05, 2010 | Epson Dot Matrix LQ-300+II Printer
I have an overload indicator on channel 2. I opened the lid and swapped the channel 2 module with the channel 5 module and the overload light followed the card and showed up on channel 5. Parasound said...
I believe that the output transistors may be bad. Without seeing the actual card, there is no way to tell. If the parts are under warranty, request a replacement board. If I remember correctly, the board is the field replaceable unit (smallest orderable part) anyway. If not, you will need instruction from Parasound about what to do next.
Dan
Sep 03, 2010 | Parasound HCA-2205AT 5-Channel Amplifier
How do I get the macaddress of the Epson LQ-300+II?
If the dot matrix printer does not have a built-in network card then it will not have a MAC address. Dot matrix printers are very old printers and I have not come accros any with built-in network card or print servers.
The dot matrix can be connected to a network print server and this will have a MAC address and a configurable IP address.
Oct 22, 2009 | Epson Dot Matrix LQ-300+II Printer
Maxtor One Touch II - installation Software
I have a disk that worked for me and I am running windows xp. I also have the website address that is supposed to have the 98 drivers which could work perhaps. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Maxtor_OneTouch_Drive_USB/Win98SE_Driver&vgnextoid=b07d8b9c4a8ff010VgnVCM100000dd04090aRCRD
Guess you could try them first and if that doesnt work I could perhaps make a backup of the disk/package/mail/ worth anything?
Feb 05, 2009 | Maxtor One Touch II E01H300 (EO1H300) 300...
160gb samsung sata II
The PC is not seeing the Hard drive. check the jumper pin for the setting on the hard drive. If you have one HD then it should be set to master or cable select. Reboot and the cmos will see the HD. If not check the cables, and last check to see if the controller driver is installed for the motherboard. The controller is where the cable connects.
rmatheson@wowway.com
Aug 21, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
The HDD speed suddenly droped
Check the pins connecting the HDD and Motherboard.
Aug 18, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
70 people viewed this question
Top Parasound Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Parasound Audio Player and Recorder Expert? Answer questions, earn points and help others
