Ef washing machine WF 7100
Hi i have a washing machine that cannot start i have lights showing on the opening of the door but the start button and timer button do not have lights, any solution please.
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
Lg washing machine wf-sp950g de ( door error )
Hi Azlan.
de Door Error usually shows when the door lock either won't undo...OR The machine won't start after the door is closed.
Both these situations probably mean that the door 'Interlock' is faulty.
The interlock is the part of the door lock which prevents you from opening the door while the machine is working.
It's part of the electrical circuit and should only be serviced by a qualified technician.
Good luck
Nomess
Feb 04, 2015 | LG Washing Machines
I have a fuzzy logic 8.2kg top loader WF-8071TTP. We had a power failure while the machine was in a washing cycle. Now I start the machine fills with water and when the wash cycle must start it give a DE...
'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 13, 2011 | LG Washing Machines
LG Top Load Washing Machine Model: WF-T7517TE , kg TURBO DELUXE. On Pushing START button , MAchine just starts and stops after a second. Message displays "dE". What to do ?
'de' on LG's stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 20, 2011 | LG Washing Machines
I have problem with lg wf-t507 top loaded washing machine when i start it work for few seconds and than show DE .
'DE' on an LG normally stands for 'door error'. It is possible that the door catch/sensor either requires adjustment, if that is possible on your particular machine, or will require replacement.
Sorry but you will need to call your local service engineer ;-0(
Good luck,
John C
Feb 27, 2011 | Washing Machines
My fuzzy logic turbo drum WF-t1340tp machine is getting a de error message. The machine start quite alright, and start to move but only for a while, then it shows the de error message. What is the...
Door Error. Could be that the lid gets bumped open while washing. Make sure it is secure, or it could be a loose connection on the wiring of the door switch itself. This feature is used to prevent small children from sticking their hands into the machine while it is operating, it switches of the working components as soon as an interruption is made with the Door switch.
Hope this helps.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Feb 16, 2011 | LG Washing Machines
My model WF s7012dn is problem.... whenever we start the machine, it shows the water level, it also starts for 2 seconds and then give beep sounds with wash and spin light flashing......
Suggest you remove drain pump out and open it up to inspect for any items stuck in the pump. Try and check pump seperately as well if no obstruction found.
Sep 21, 2009 | Washing Machines
I have Model WF-S6607?WF-S6607TC. Washing Machine. Loaded the clothes, pressed the POWER button, pressed the WATER LEVEL button, pressed the PROCESS button, and pressed the START/PAUSE button, But few...
Apr 04, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf 250 aquaries
try changing your water valve this should sort problem
Jun 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
