Question about RIM BlackBerry Storm 9530 Smartphone
MY BLACKBERRY BOLD 9315 IS GETTING 513 RELOAD SOFTWARE MESSAGE
  • 7 Answers
SOURCE: need to reload software 513 blackberry
the Application error 513, reset message says that the device OS is toasted and needs to be rebuilt. In order to do this, you need to have Blackberry Desktop manager on your computer, your data cable, and a download for your device software. Either from blackberry or your carrier. The easiest method is to download and install the device software. Once it's installed, launch desktop manager and plug in the phone. If the phone is detected, you will be prompted to update. Follow the prompts. If not, you will have to do it the hard way. open command prompt (start>run>cmd) and goto C:\program files\common files\Research in Motion\Apploader Then choose Loader /NOJVM That's going to rebuild the blackberry.
Posted on Jun 05, 2009
  • 10 Answers
SOURCE: how do i reload software 513 for my blackberry storm.
What you need to try to do is reinstall the blackberry OS (operating system) on your device.
Assuming you have verizon
First install Blackberry desktop manager it should be in the CD that came with the phone.
If you can't find it download it https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=5E695511C1F9656B8E3E63DAB060F469
Then download the OS software for your phone http://vzw.smithmicro.com/blackberry/download.aspx?ct=personal"
Install it
Connect your phone to your computer and start Desktop manager
Click on application loader, on update software click start, click ok on USB pin selection.
when you get to the device backup and restore options, click settings and make sure backup options box is unchecked and device data boxes are both checked, click ok, click next, skip the email signup stuffs,and finish.
After the software is installed the phone should boot back up
Posted on Jul 13, 2009
fleshgear
  • 541 Answers
SOURCE: reload software 513 error
After typing an incorrect password ten times and restarting the BlackBerry smartphone, the following error appears:JVM 513
All of the data and applications on the BlackBerry smartphone have been deleted and The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone (Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader)
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps:
1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2) Double-click Application Loader.
3) Click Add/Remove Applications.
4) Type your BlackBerry smartphone password and click OK.
5) Select the check boxes next to the names of the applications you want to load.
6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
7) Click OK.
8) Click Next > Finish
9) When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
Posted on Aug 10, 2009
SOURCE: Reload software 513 for blackberry storm
I'm not too sure if all your data will still be there. But you can fix this yourself. You should be able to reload the device software with the Blackberry Manager.
Posted on Sep 04, 2009
prettynails4
  • 283 Answers
SOURCE: Blackberry Bold 9700 - RELOAD SOFTWARE 513
all you need to do is sync your blackberry with your blackberry desktop manager and run the application loader. you will lose all data on the phone because you will be re-installing the software
Posted on Mar 03, 2010
Reload software 513
Hi, the Application error 513, reset message says that the device OS is toasted and needs to be rebuilt. In order to do this, you need to have Blackberry Desktop manager on your computer, your data cable, and a download for your device software. Either from blackberry or your carrier. The easiest method is to download and install the device software. Once it's installed, launch desktop manager and plug in the phone. If the phone is detected, you will be prompted to update. Follow the prompts. If not, you will have to do it the hard way. open command prompt (start>run>cmd) and goto C:\program files\common files\Research in Motion\Apploader Then choose Loader /NOJVM That's going to rebuild the blackberry.
Jan 19, 2011 | RIM BlackBerry Bold 9700 Smartphone
My Bold 2 9700 smartphone is showing blank screen with the message reload software 513. Also, the phone is not connecting to the desktop manager eith using the USB cable or through the Bluetooth.
Force a reset by loading version 5 desktop software on your laptop first and then connecting the BlackBerry to it. It may take some time for your pc to recognise that the BlackBerry is plugged in, so be patient!
When it connects, reload the firmware.
Oct 12, 2010 | RIM BlackBerry Bold 9700 Smartphone
I had a "reload software 513" error and had to reload software to get my blackberry bold to work. Now when I talk with people they can't hear me.
Download the Blackberry Desktop Manager from https://www.blackberry.com/Downloads/entry.do?code=A8BAA56554F96369AB93E4F3BB068C22, after downloading run the setup and after completing this step. Connect your blackberry to your computer and open the BDM (Blackberry Desktop Manager). The application would recognize your blackberry, when it shows that your smart phone has been connected, you can now run the software. Make sure your computer is connected to the internet.
Run the software and allow it run. This process may take few hours to complete once done it would automatically reboot your phone and you are good to go.
Thanks
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
Reload software 513 on blackberry bold 9700
you need to call att and they can get you to data support and they can fix it.
Feb 28, 2010 | RIM BlackBerry Bold 9700 Smartphone
Reload Software 513 in Black Berry Bold 9000 series.
Your Blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings. Download the Blackberry Desktop manager and run the application loader.
Aug 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
How to reload software 513?
I have a blackberry curve that drove me crazy because the application loader didnt work with mine either but here is what I tried and it worked for mine so hopefully it will work for yours. First, go to the blackberry.com website and click on software. Then click on device software. Select the version that is compatible with your phone. Be sure that your phone is connected to the computer with the USB cord that is came with. Then click download and follow the instructions from there. This should reload the software on your phone.
Jul 20, 2009 | RIM BlackBerry Storm 9530 Smartphone
Need to reload software 513 blackberry
Mar 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
29 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
