Printer won't print
I have a new old printer. Hooking it up via USB to traditional conversion cable (pegs??)(printer does not have USB port. I downloaded the driver. It is an HP 612C. OPen word document, send to print and the machine engages, the cartridge mechanism moves and the paper begins feeding - then, stops, and the light that has a picture of a piece of paper with an arrow begins bllinking and no printing takes place.
    Genius:
  • 1,011 Answers
Sounds to me the printer is trying to tell you that there is a paper problem.
Please check ther entire paper path for any scraps of paper.
Also, make sure that the feed rollers are clean and soft.
Posted on May 09, 2009
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
I have an old serial printer that works fine, I can not connect it to my new computer via a parallel to usb cable convertor on windows 7!
Hi craig931, First try downloading the latest driver of your printer and your usb converter compatible for windows 7. Second Checked your device manager if your printer and usb to parallel driver properly installed, it should be there. If not yet installed try using different usb port one at a time until the cable have been detected. Third if you see already the printer port force to change it to USB001 or Com1, then try to print. regards,
Sep 26, 2011 | Office Equipment & Supplies
Can i connect usb port to printer port for network printing
No. The USB port on your cable modem is intended to be used only for connecting a pc to the network. Sorry for the bad news.
For network printing you can use a dedicated print server like Edimax ps-1206u, a great device that make even old printers to get on the network via USB and Ethernet ports it haves
Aug 07, 2011 | Linksys CM100 Cable Modem
I have a citizen prolaser 6000 laser printer, it emulates HP Laserjet 3, I want to connect it to my laptop via a usb interface cable, currently it is connected to the printer port of a desktop (lpt1 for...
There is three things that you will need:
Proper port set up on laptop device manager (Check settings) LPT1 is for a parallel port - Need USB Correct Driver for the Citizen 6000 Pro Laser (Windows should auto install) Hub that will communicate via USB to the IEEE 1284 Printer via cable.
Driver Site: http://www.driverfiles.net/Printers/Citizen/Prolaser-6000-Printer-Driver/download/page,sh,38839,389,12,.html
I hate to suggest, but you may have to call Microsoft Citizen Tech Support for suggestions on the Hub that will communicate via USB properly. Check your manual for setup options.
TF
Jun 02, 2011 | Office Equipment & Supplies
HP LaserJet 1320 will not print
may be its problem *********** board. install another computer if you saw detect a new hardware so your printer is OK or no detect hardware devise then fault your printer mother board,replace it and buy a new mother board.
Best luck
xptareq2000
other help
xptareq2000@yahoo.com.
Nov 09, 2009 | HP LaserJet 1320 Printer
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Nov 30, 2008 | Office Equipment & Supplies
PRINTER WONT PRINT
If you has been connected your printer via USB be sure that the printer port is "USB Virtual Port" and NOT Lpt1
Oct 07, 2008 | HP LaserJet 4000tn Printer
66 people viewed this question
k24674
