Question about Audio Technica AT-PL120 Turntable
Distorted sounds Hello, when I play my records on my new audio technica AT-PL120 turntable through my sansui solid state 4000 reciever, the sound is very compressed sounding and very distorted almost crunchy. can anyone help me, thank you!
  • maweeks85 May 09, 2009
    wikkid420,
    Thank you very much for your response, unfortunately after looking high and low on my player i was not able to find a volume control knob, and i also verified that the cables were properly connected to the correct jack, but it still did as it was doing before. But i noticed now that even when i turned down the volume on the reciever, the sound was still crunchy and distorted when it was playing very softly through the record player, you know how you can still kinda here it even when the reciever is turned off/down. Thank you once again, and if you have any more possible options i would love to know.
  • bczerkie May 11, 2010
    Did you set the weight to correct setting?
    My technics is balanced then add 1.5, yours should be listed if not just heavy enough to prevent skipping.
    Did you clean record?
    speed setting? does it have a strobe?
    needle not in stylus correctly, maybe twisted slightly?
    check closely to see if any paper from the album sleeve has started to stick to the record.
    And do remember after listening to cd's for years records do sound scratchy and as eddie murphy once said hey this sounds like s***!.
    Hope this helped
    Bill
The AT-PL120 uses a magnetic cartridge to extract a music signal from the record. Magnetic cartridges all put out a very weak electric signal, and so their output must be strengthened, or amplified, to where it is as strong as the input from, say, a CD player. This amplification is provided by a pre-amp. If your receiver has dedicated "phono" inputs the pre-amp circuits are already in the receiver. If you do not have dedicated phono inputs you must either buy a pre-amp, or buy a magnetic cartridge turntable with a pre-amp built into itself. The AT-PL120 has a built in pre-amp. You can switch the AT-PL120's preamp on or off. The switch is located under the platter at the back side of the turntable. Take the platter mat off and turn one of the platter's holes to the back and you should see the switch through the hole. If you push the switch to LINE OUT the preamp is turned on and the turntable sends an amplified cartridge signal out the cables which MUST be connected to a receiver inout suitable for a CD player (a "high level" input). If you push the pre-amp selector switch to PHONO OUT the turntable sends the weak unstrengthened cartridge signal out the cables which MUST be connected to the receiver's dedicated PHONO inputs so the signal can be amplified with the receiver's own pre-amp circuits.
If everything is set wrong (i.e. LINE OUT (pre-amp on), and connected to phono inputs) you are applying two steps of strengthening to the turntable's signal which is too much. The resultant sound will be garbled. Try not to do this!
The other way to do everything wrong is set the pre-amp switch to PHONO OUT (pre-amp off) and connect the turntable's cables to a high level input. If this happens the turntable signal receives no amplification and the resultant sound will be thin and weak.
Posted on May 18, 2009
    Scholar:
  • 96 Answers
It sounds like your turntable is over-driving volume into your receiver. If the turntable has a volume control, turn it all the way down first, then turn your stereo volume up to the level you would normally listen to and slowly turn up the turntable volume until the music sounds right to you. Use the volume control on your receiver to control over-all volume. If your turntable does not have a volume control, make sure the cable you have connected it with is running from the "line out" jack and not the "headphones" jack. Let me know if this helps :)
Posted on May 09, 2009
  • 585 Answers
It sounds as though the turntable has an preamplifier built-in. The Phono input of the Sansui is probably matched to an unamplified magnetic cartridge. If that is the case, yes, it is terribly overdriven. Try connecting the turntable output to the Tape or Auxilliary input to see if that helps.
Where can I purchase a replace tonearm locking clip for an Audio Technica AT-PL120?
Audio technica will send you a replacement clip free of charge. Just send their service department an email asking for one.
Feb 21, 2012 | Audio Technica AT-PL120 Turntable
My brand new audio-technica AT-LP60 turntable has skipped on every single record I've played in it (even brand new ones). Always happens at the same spot - towards the end of the record, halfway...
hi,
Do one thing adjust counterweight on the back of the arm to 1.5gm or 2gm by rotating the counterweight. It will give some more pressuer on the styles and will avoid the jerking
ok
Aug 04, 2011 | Audio Technica AT-PL120 Turntable
Turntable turns on, but when "start" button is
Pull the aluminum record platter where the record sit on and check to see if the belt off. If it is broke you may need a new one.
Dec 02, 2010 | Audio Technica AT-PL120 Turntable
Brand new audio technica at-pl120 turntable not powering on; cant get turntable to spin
HELLO!
I don't know which country you are from, but if the mains plug has a fuse in it then replace it with the same type. If that does not do the trick take it back back where you bought it and get a refund or a replacement! There may well be an INTERNAL fuse inside the unit on the power supply unit which may be at fault. If it is under warranty don't open the turntable yourself - take it back - I WOULD!
All the best!
Jul 12, 2009 | Audio Technica AT-PL120 Turntable
Sound very distorted
This turntable has a preamp switch on it, which is probably on and what is causing the distortion. Take off the metal record platter by lifting up on the two holes gently. Turn the pre-amp switch to 'off' and then try it again. This is probably it...
Or you can plug it into an input that doesn't have a preamp and that should work.
Dec 25, 2008 | Audio Technica AT-PL50 Turntable
What do I need to hook up the AT-PL120 to an imac
I use Audacity. It's a 100% free sound editing software and works great for vinyl transfers...Linky
http://audacity.sourceforge.net/download/
Jun 16, 2008 | Audio Technica AT-PL120 Turntable
Audio-technica atp-2 cartridge with a atp-n2 stylus
Make sure the cart is connected properly, and check the manufacter's instruction with that cart. sometimes tonearm height and weights need to be adjusted for proper torque and sound.
Oct 26, 2007 | Audio Technica AT-PL120 Turntable
Audio Technica AT-PL120 Turntable Logo
686 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
