Question about Duke E101-G Gas Single Oven
Duke 613 convection oven wont relight after doors are opened and closed
4 Suggested Answers
  • 1238 Answers
SOURCE: problem with duke 613 commercial oven
http://www.4emweb.com/search.asp
try this web site. I found a list of wiring diagrams here..If you have a problem getting there, let me know and I will give steps as to how.
Good luck.
Posted on May 24, 2009
SOURCE: Duke Convection Oven won't heat past 250 degrees
Most likely a heating element.
Posted on Nov 08, 2009
  • 106 Answers
SOURCE: hi,
Check that the elements are high quality, dont use cheap elements, also replace all the elements and all are working, do not leave the door open while heating for along time. Do not power cold water on them while hot to clean let them cool down gradually.make sure the termina conection to are not loose during replacement. swicth off when you dont need to use for a long
Posted on Jul 29, 2010
Our electric convection oven heats up and when you open the door and close again it no longer heats, fan stays on and the light goes on when door open and off when door is closed, any ideas?? Thanks
Hi, You can look at the micro switch on the oven door, sounds like it might have been installed on a normally open auxiliary rather than a normally closed aux. hope this helps
Oct 09, 2014 | Ovens
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
Hi I have a Bosch Double Oven/convection Oven I
Don't know but have you tried the old tea towel in the corners trick to see if its the hinge alignment and not the seal? Put two tea towels in the lower corners sticking out of the oven part way and push the oven door closed a few times. Saved me from trying to replace the seal.
Oct 04, 2013 | Ovens
Hi, the elements on my duke e101-e 240v single phase convection oven keep going out every 3 to six months...is there any other reason why they would go out so often?
Jul 29, 2010 | Duke 59-E4Z Electric Single Oven
Door does not shut completely
OVEN DOOR HINGES WILL NEED REPLACEMENT IF YOU PUT ADDITIONAL WEIGHT ON THE DOOR THEY WILL SOFTEN THE SPRINGS AND THE DOOR WONT FULLY CLOSE.
May 29, 2010 | Electrolux 30" Built-In Double Electric...
Why should the cooker burn that hot, when you can cook most things at a max 220Celsius
Sep 27, 2009 | Duke 59-E4Z Electric Single Oven
Problem with duke 613 commercial oven
Good luck.
May 23, 2009 | Duke 613-E1V Electric Single Oven
My covection oven does not heat up once food is put in
on the gas valve there is an adj. for the pilot size, maybe too small , would try increasing the pilot and see what happens.also the thermocouple might be on the way out ,you might want to replace that and try oper. go with thermocouple first, then try pilot size dont forget to vote tks. monomoy
Feb 20, 2009 | Hobart HGC202 Gas Single Oven
Duke E101-G Gas Single Oven Logo
Top Duke Ovens Experts
Dennis Boxerman
Raymond Richards
Raymond Richards
Andrew Taylor
Andrew Taylor
Are you a Duke Oven Expert? Answer questions, earn points and help others
