Question about Panasonic PV-DF2704 27 in. TV/VCR/DVD Combo
We have a blue screen, what do we need to do to get the TV back o
When we turn on the TV, we just get a blue screen.
    Problem Solver:
  • 3 Answers
Hit the input button on the remote,once or twice to get picture.or it may be labeled audio/video
Posted on May 09, 2009
    Scholar:
  • 85 Answers
Blue screen usually meens that you have no input signals to set via scart/rf lead etc, make sure that all your leads/cables are pushed in properly if still blue screen read instruction manual that came with set, if still blue screen get a tech' in!
The whole screen turned blue while shifting it to get to inputs. Now I can't get anything but a blue screen.
If you have not turned the TV off yet then do that. Turn it off and let it power down completely. If it has a fan then let the fan stop spinning. Wait about 5 minutes then turn the TV back on. If you still see blue then you may need a new bulb or the light engine in your TV has gone bad.
Feb 28, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
Lines, then no picture, then turns off
Remove Front panel look for screen/focus controls adjust them you have R/G/B for each tube ,you have screen drive controls as well as focus Start with red turn green and blue off adjust each one untill you have a black/white picture, If screen drives are to high TV will turn off.Also if STK ICs are bad TV will not come on there is a blue capacitor behind hori output Transistor that also burns out CK it as well.LET me know if any of this has helped you or if you need more information.
Aug 06, 2009 | Sony KP-57HW40 57" Rear Projection...
My TV Screen turns green or blue after 10 minutes of the tv on
You have a chip that is overheating due to heatsink coumpound being dried up. You need to find that chip and heatsink and apply new compound to both parts.
Mar 18, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
Nov 20, 2008 | LG 32LB9D TV
Screen turns blue then shuts off.
I already replied but once again..
Symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Sep 05, 2008 | Toshiba 51H84 51" Rear Projection...
Tv turns blue the shuts off.
symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Blue screen sony
blue crt shorting use crt restorer to lift short or replace picture tube /crt
Aug 19, 2008 | Sony KP-46WT500 46" Rear Projection...
My picture turned blue after i unplugged the tv
did you ever fix the problem?
my tv went blue screen also
needed to charge the lamp so did but now can't get the new lamp to work
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen
convergence ic and resistors require replacement and that you need to check for cracked solder.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 28, 2007 | JVC AV-56WP74 56" Rear Projection...
Panasonic PV-DF2704 27 in. TV/VCR/DVD Combo Logo
1,445 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
