Question about Zebra 105Se Thermal Printer
Skipping labels Zebra 105se printer prints 1 label, skips 5, reset head, skips 2, prints 2, skips 5, need help recalibrating
    Scholar:
  • 51 Answers
Do you use adhesive labels? It looks like the printer is unable to make the difference betwen the labels. Verify that the printer it's not set on Continuous mode for the media type. Verify if there is any label (or pice of label) stiked on the upper media sensor (gap sensor). You can locate the upper media sensor using the User Manual (page 74). There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
You can clean the sensor with an coton cloth dampened into isopropylic alcohol.
Here is the link to user manual:
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
Posted on Jun 03, 2014
jc2it
  • 58 Answers
SOURCE: zebra 105se printer is printing out of the label on the wright side
It would be best if we had more information, or a picture.
For instance if you told me as the label is printing it does not print on the label, and it appears shifted to the right or front, then I would say, you need to re-calibrate the printer for that label.
If you were saying that the printer is printing on the right side of the label as you face the printer and watch the label exit the printer, then I would say, that the label size in the software is wrong, or the transfer ribbon is loaded incorrectly, too far to the right as you face the label exit path, OR the labels are loaded too far to the left as you face the label exit path.
Here is a link to a manual that may help as well.
Posted on Feb 02, 2008
  • 45 Answers
SOURCE: ZEBRA 105SE
The label sensor is not detecting the gap between the labels.
Make sure the labels are loaded all the way to the left (as viewed fron the front) and make sure the label guide (near the back of the printer) is set to keep the labels from wandering away fromt he sensor.
There is a pair of infrared emiter and detector located above and below the label path. As label pass between, these measure the leading and trailing edges of each label.
If you haven't already done so, calibrate the printer, by using the "Online", "Calibrate", "Online" buttons. If the "Feed" button doesn't feed just one label, you'll need to adjust the label gap sensors. This can be a bit trick if your labels are very narrow.
There should be a small pcb on a shaft under the label path. Note its current location, then slide it left or right to get a better signal, and try the feed button again. On my Zebras, the sensor is not in the middle of the PCB. Look for a small metal "can" on the PCB and center that.
The upper sensor is more difficult to adjust, but if you manage to spot a very small PCB above the labels, it will be easier to line these up.
If the labels are extemely
Posted on Sep 18, 2008
  • 53 Answers
SOURCE: zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Posted on Jul 10, 2009
  • 1121 Answers
SOURCE: My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Posted on Jan 13, 2010
  • 31 Answers
SOURCE: Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
Posted on Jan 31, 2010
The printer prints one label and skips another one
First, I need to admit it. This is the worst printer I have ever used. I had all kond of troubles with it.
The skipping labels problem was my misery for 2 days to. I had to find out that my labels were falling out of the printing area generating a new page (label). Go back fix your width. Make sure your label fits one page (label). Print again. That's what I did. Good luck.
Mar 27, 2014 | Zebra LP 2844 Thermal Printer
Advancing blank labels inbetween printing
Dec 03, 2013 | Zebra 105Se Thermal Printer
I have a Zebra 105Se zebra Printer for testing. When a label is printed it just prints 1/4th of the label,then the printer stops and paper/ribbon light,Pause light and data light is on.When I open the...
Make sure that both ribbon and media paths are clean (no glue, or sticked labels). Make shure the ribon and the media are corect installed on their paths.
Sep 23, 2011 | Zebra 105Se Thermal Printer
Jan 13, 2010 | Zebra Z4Mplus Label Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
May 28, 2009 | Zebra 2746e Thermal Printer
Zebra 105se blank labels problem
I would say the roller isn't the problem. I had the same problem on many Zebra printers, but often the calibration helped. Then it could do, when printing task label is for larger/longer than the label size is set in the printer system (conflict of software with printer settings after calibration). It could be set too down to bottom in Y axis. Or it could be in the software settings - as action after print - not sure.
Try to open the printer queue while the label is printed and check if the label has proper number of pages or there's 1 page more. If it is the right number - then the problem is on printer side (recalibrate, reflash it). If the number is about 1 higher, the problem is with settings of the label size (barcode software, printer settings) or action after print on PC side.
May 30, 2008 | Zebra 105Se Thermal Printer
TLP 2844 skips over labels
The first thing I would do is to default the printer then run a width calibration. The instruction are in the user's manual that should have come with the printer. If the instruction did not come with the printer I can provide the instruction.
May 07, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Skipping 1 mm (regular intervals) while printing labels
1-try to recalibrate labels
2-make sure the label size is correct in the settings:
here is the link for the driver. :
http://barcode.toshibatec.co.jp/Eng/download1.html
Nov 02, 2007 | Toshiba TEC B-SX4 Thermal Label Printer
Zebra 105Se Thermal Printer Logo
190 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
