Kalenji geonaute afterbchanging battery short ac pad to reset
SOURCE: Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...6e1fe0e.jpg
Posted on Jul 06, 2008
SOURCE: I have just replaced the
To all who need to change their Timex Ironman Triathlon watches:
It is a little confusing, but this is a watch you can change the battery by yourself!
First you will need:
-A big clear area (i.e. a table or counter) with lots of light to see what exactly you are doing.
-Small screw driver (like the tiny ones for a glasses care kit)
-Paper clip
Directions:
1. Remove all screws from the the back of the watch (there should be 4). Make sure that you take note of which screws are coming from which spot on your watch and keep them separated as such.
2. Next, you should see a white circular sticker with directions on how to change your battery. They aren't clear as "how to" but they are the basics.
2a. Take off the white sticker once you have memorized the places it is pointing to; set it up as such in front of you so you can refer back to it from time to time.
2b. You should see two silver pieces. One should be a circle (which is the battery), which is held in by another silver piece. This unlatches. In order to do so, you need to simply pop it open on one of the sides (as it tells you in the directions). You may use the same screwdriver or even a paper clip works wonders!
3. Replace your battery (should be CR2016) with the + on top, facing towards you. make sure it is flat, not just shoved back where the old battery was. This make take some extra time and patience to make sure it is done right.
4. Snap the silver part back into place (should look like it is holding the battery in place i.e. a gate).
5. THEN: this is the most important and confusing part in my opinion. On the white sticker the directions read: "after battery insertion, short pads to reset". this should look something like an oval with a line cutting it in half (vertically). It is not on the battery but next to it. You will need the paper clip here to hold down the right most side (at somewhat of an angle). this should do it! you'll know if your digital faces flashes numbers at you and may even light up. Make sure you hold down long enough.
6. Once you have the numbers flashing, you are good to go. Put the back of your watch back on, taking note of which screw goes where. Then, set your watch accordingly and you have just changed your watch! Ta-da!
Follow these steps and you should be good. Good luck to all!
Posted on Apr 22, 2009
  • 299 Answers
SOURCE: CHanging battery on timex expedition, cover says
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
Posted on Apr 15, 2010
escapement
  • 2334 Answers
SOURCE: I'm trying to restart a
Make, model, all numbers, please.
Posted on Apr 03, 2011
Saltyjet
  • 13 Answers
SOURCE: how can I reset the
from the solution mentioning the sticker arrow, he's right but no one tells us how.
Here's the real solution:
1. remove the back cover of the watch
2. remove one screw holding in battery clip
3. replace battery
4. replace clip and screw
5. ** take one of the back cover plate screws and place it in the hole that the sticker arrow points to
6. touch your screwdriver to the inserted cover screw and the screw holding the battery clip
7. holding the internal portion of the watch firmly in place, remove the cover screw from the hole you placed it in, but very carefully(tweezers may be of use)
8. reassemble as normal. (prior to reassembly it is always a good idea to place a tiny amount of silicone based lubricant on the small o-ring seal around the edge of the battery case. this seal provides the water resistance touted by the manufacturer this can be done with a cotton swab or toilet paper, and clean all excess lubricant from battery case).
Posted on Aug 06, 2012
I have a Fossil Big Tic BG2130 Watch which has 3 batteries. I have replaced all 3 but the digital part does not work still. Is there a reset somewhere
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic....
Aug 04, 2017 | Fossil Watches
Timex Rush Indiglo Watch: shorting the AC pad to the battery
If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic.
There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.
I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery..
Sep 05, 2012 | Timex Indiglo Watches
I can't remember my Toshiba L300 setup password to enable me boot from CD.
There is usually a couple of pads underneath the laptop that will short out the BIOS battery which will reset the BIOS settings.
  • Disconnect the AC and remove the battery
  • Remove the memory
  • Peel back the black plastic film underneath but don't remove it entirely
  • Attach a piece of adhesive tape on the underside
  • Insert a memory stick
  • Stick the tape down on the case
  • You now have access to the two shorting pads named B500
  • Reconnect the AC and short out these pads.
  • Power on the laptop with these pads shorted out until the Toshiba logo disappears
  • Remove the AC and remove the memory stick
  • Remove the tape and replace the black plastic film
  • Reinstall all the memory
  • Replace the battery and the AC
This should have wiped out the BIOS passwords. Use enter to get into the password protected areas.
Jul 22, 2011 | Toshiba Satellite Pro L300 Notebook
How can I reset the "short AC pad and battery (+) on timex expedition
You know where AC pads are right? If you don't know, look at the sticker. there is an arrow on the sticker. An arrow points out 11'oclock.
After insert the bettery, you just touch the golden pads with metal screw. that is how to short AC pads.
Oct 13, 2009 | Timex Digital Expedition watch
Countdown timer will not beep at end of countdown
remove battery - replace battery and short AC Pad and battery to reset
Aug 09, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
After replacing a battery in a timex ironman with data link, they tell you to short the ac pad and the vss pad. Were are those points located?
You will find them on the module itself.
So after replacing the battery look on the PCB (printed circuit board) for the letters"AC" and "VSS". Adjacent to these markings there should be little contact points (probably gold or silver looking in colour)
Use a paper clip or similar and bridge (short) these two points simultaneously. Please rate my solution.
Jul 26, 2009 | Timex IRONMAN Triathlon Data Link T53722...
How to reset the safe house alarm very old style model # 49-470A
i bought house alarm second hand and it has reset it self to factory setting 1234 but on pad its say called engineer to reset can you help
Jun 21, 2009 | Home Security
Timex rush new battery reset
good morning ! you need to use the pointed twisser to short the two reset pad ! thanks !god bless !...
Sep 02, 2008 | Timex Rush Sports Watch
May 31, 2008 | Timex Advanced Data Link 53722 Wrist Watch
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
