Question about Toshiba 43H70 43" Rear Projection Television
Power loss when I try to turn on the tv using the power button on the tv, nothing happens. Only the red light on the front of the set lights.
Throw it out, and buy a new one!
Posted on Oct 19, 2007
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
Why is the power button blinking on then off, i can't turn my tv on
The set is in shutdown because of some internal problem. Can be almost anywhere in the set---
Mar 13, 2012 | Televison & Video
When I turn my ps3 on, there is no audio/video. I don't think it's a software update problem, as I was playing my ps3 about two/three hours ago. I turn it off at the back, chill for a couple seconds, then...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 25, 2010 | Sony Playstation 3 (PS3) Console
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
PS3 can turn on, but T.V screen is black
turn power switch on in the back. red light on in the front, hold the power button until system turns back off. this resets all hardware settings. if this doesn't work and the system is ok (green light) then you have a connection problem to the tv
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
No picture but have green light
  1. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  2. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
May 24, 2009 | Video Game Consoles & Games
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Toshiba TV, no power, red light flashing
Unplug the TV for 2 minutes and plug it back on.
It should work.
Feb 09, 2008 | Televison & Video
Tv will not turn on
The blinking red light is telling you that the set did not start up due to an overvoltage somewhere in the set. Most likely the main power supply has a fault like a bad regulator IC or a component associated with it, or there is a fault in the sweep power supply somewhere. if you have no electronic repair experience, play it safe and call out a tech to assist you with this repair. Good Luck.
Mar 19, 2007 | Toshiba 43H71 43" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
