External hard drive
I accidently unplugged my external hard drive. And not knowing that it is wrong to just put anything and everything on it my computer will not recognize it now. I believe i put some things on it that my computer needs to recognize it. Can someone please help?
  • austin21 May 09, 2009
    hard drive connects thru USB and Joe I did what you said and it did not work. Any more suggestions. It shows up everywhere accept "my computer" and in disk management
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    How does the external hard drive connect to the pc, thru USB or firewire?
  • 4,338 Answers
refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive
Let me know....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 09, 2009
  • JDTec
    JDTec May 09, 2009
    Did the external drive come with software? If so, reinstall the software and then plug the drive in.
    If the software is on the external drive. Plug it into another computer and copy the software onto a flash drive, then install on your PC.
    Also, check in the Device Manager, and make certain the the drive is not recognized as "other device" or exclamated out.
    Also, click on the "Start" menu, click the "Run" command, and type in: services.msc , scroll down until you see both these services. right click on each of the services about and select properties, on the general tab, change the startup type to "automatic" and click the start button under the service status. do this for both of the services.
External hard drive format recovery
They are probably still there if you have not written any new files to the drive. read this link http://www.tomshardware.com/forum/285728-32-data-back-formatted-drive-recovery
Dec 22, 2014 | Western Digital Computers & Internet
Hard drive not detected by the pc
ur hardisk is gone bad u cant do anything to fix it if ur data is imp try contacting a data recovery center
this problem occurs when the harddisk get a hard hit on its or if its was accidently hit on the ground
Dec 21, 2013 | LG XD2 500 GB USB 2.0 Portable External -...
USB 2 is missing from my External Hard Drive 80GB
by the time you have stopped the formatting process has already started now download some data recovery applications then check it
Jan 30, 2013 | Freecom 80 GB USB 2.0 Hard Drive
External hard drive was dropped and now no power
You may have accidently broken some of the internal components of the external enclosure. If you have the know how, you should take the hard drive out and test it in a computer to see if the hard drive is still good. If the hard drive is still good, you can get away with buying another enclosure. If the hard drive isnt good, your better off just buying another external drive.
Mar 05, 2011 | Seagate USB 2.0 External Enclosure + 400GB...
For some reason when I run the smartware to unlock my drive I get the error message "The application has encountered an unexpected error and is now exiting." I've used this drive for over a year...
Update the software again and unplug for 30 to 30 seconds. Unplug the USB from computer and External Hard Drive. Unplug the AC Adapter. Replug everything, the correct driver will be installed
Jan 02, 2011 | Western Digital My Book Elite 2TB External...
Seagate Barracuda external hardrive - damage to usb connector on
Assuming the drive itself is still ok (it sounds like it would be), then yes, you can put the drive into another case or directly into the motherboard if you know how to do that.
May 27, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
How do I completely reset my external hard drive
1. You need to check how much free disk space is available on your laptop.
2. You need to check what duplicated files you have on both the laptop and the external hard drive and which is the latest version.
3. You need to decide to move the latest versions of the data files from the external hard drive to the laptop. This automatically delete these from the external hard drive. The older versions on the external hard drive can be deleted.
4. Now you need to check how much data is stored on your external hard drive.
5. If the amount of data stored on the external hard drive exceeds the available disk space on the laptop, then you cannot copy these files to the laptop.
6. If you have sufficient disk space on the laptop you can copy the data from the external hard drive to the laptop. I suggest you make a folder to copy this data to it.
You can now delete all the data from the external hard drive or you can format the external hard drive to make a clean external hard drive.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
External hdd not detected
Formatting a drive means resetting it to manufacturer settings
And deleting everything in there, this solves most of hard
Disk problems, mp3s ipods ect..
if its powering on without being connected to anything do the following.
connect it via usb cable to your pc, or if it’s a hard drive its already connected.
click on start, right click on my computer and go to manage
in the table select, "storage" then "disk management"
in that table find the drive that relates to your mp3 player
if its not there "buy a new mp3 this is faulty" if its there
then right click on it and select "new partition"
you just next next everything and then format it and after
a while it shows "healthy2
unplug it, plug it back on and that's it your drive is fully working
now move what ever you want to it just like before.
Mar 08, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Iomega mini max external HD slowing things down
the hd external iomega 500 gb minimax have a litle noice and don't work dont conect whit my computer.
Mar 06, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Computer not showing external hard drive
Try the following : -
(1) Connect to any other Computer and Run Disk Clean-Up Wizard under Tools from Windows Maintenance.
(2) Now, connect your Hard Drive to your Computer and will be detected.
Jul 01, 2008 | Western Digital 500GB My Book World...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
