Question about Compaq AlphaServer ES40
SROM 0 No mem error - Compaq AlphaServer ES40
TI-84 calculator clear data on x,T,n
Press [2nd][+] to open (Mem)ory management tool.
Select [2:Mem Mgmt,Del]
Press [2:Real]
Scroll down to reach X;
Press the DEL(ete) key.
The X-variable will disappear from the list. and the stored value will be replaced by 0.
You could also just use 0 [STO>][X,T,Theta,n] to reset value to 0
Feb 28, 2012 | Texas Instruments TI-84 Plus Silver...
My printer shows memory error on its screen why?
Mem test failure replace Dimm 0 or Mem test failure replace Dimm 1
If either of the are the messages displayed, the problem lies with the mother board (formatter).
DIMM 0 = On Board Memory - cannot be changed. DIMM 1 = Add On Ram - Can be Changed
Make Sure the printer firmware is up to date FIRMWARE
Most Likely the formatter board would require replacing.
Feb 03, 2011 | HP LaserJet 2420dn Printer
MEM TEST FAILURE REPLACE DIMM 0
DIMM 0 is the memory slot under the keyboard.
Apr 15, 2010 | HP Compaq Presario 3005US PC Notebook
Problem for HP LaserJet P3005n Printer MEM TEST FAILURE REPLACE DIMM 0
Apr 15, 2010 | HP LaserJet P3005n Printer
Printer hangs and after displays a message"MEM TEST FAILURE REPLACE DIMM 0"
This is a straightforward error message saying that the first bank of memory is defective and needs repalcing. All you need to do is locate the module in the memory bay and replace it with a similar one. These only cost a few dollars so it is avery cheap repair.
Sep 24, 2009 | Office Equipment & Supplies
SONY NWWM MEM AAD2 mp3 walkman, format error
my SONY NWWM MEM AAD2 mp3 walkman, 1 gb tells me format error when ever I try to change menus and will not play music, can you help me ?
Jul 07, 2009 | Sony Walkman NWZ-B135 MP3 Player
Acer Aspire 4720 RHEL4 Installation
again install linux in between the installation there will be option select linux boot loader , and one more think linux partition space should more then windows partition
Mar 26, 2008 | Acer Aspire 5100 Notebook
Unable to Install Red Hat Linux Enterprises 4
when the time of installing only you have to take linux boot loader then it will show both operating systems otherwise i think the problem is monitor configuration in linux installing
Mar 24, 2008 | Computers & Internet
Memory Card
check if your e2 can handle a 2gb mem card, most unit made three years ago cant handle even a 1gb mem card. check your unit capability first before buying a new mem card . [:0)
Jan 04, 2008 | Electronics - Others
Compaq AlphaServer ES40 Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
