Question about Toshiba Satellite A135-S4527 Notebook
Toshiba a135 ask for password,i was told there is a batt. that can be taken out and put back in to reset
  • captainjcd64 May 09, 2009
    thanks ,I'll try that know that i now were to find cmos battery.
    Sergeant:
    Novelist:
  • 197 Answers
There should be a battery on the motherboard of the notebook itself, but you'll have to take the unit apart to access it. Usually, it is underneath the unit, so you would have to remove all the screws to take the notebook apart at the seams. If you aren't sure of yourself, I would advise taking the notebook to a qualified repair store to have them reset the CMOS.
If you do decide to attempt this, proceed with caution, make sure you don't force anything to remove it, and also if you must disconnect any wires, make a note of where they reconnect.
Posted on May 09, 2009
Toshiba satellite A135-S2276 cannot get pass bios password and none was set
Try removing internal battery this is ussually a small battery on the motherboard which keeps in its memory date and time ,hard drive details ,passwords etc.
Some batteries are easily removeable some have to be desoldered so it losses whats in its memory. The laptop is then switched on to see if the password is gone.. Then battery put back. Some laptops have to be taken to manufacturer to take password off..Good luck
Jan 28, 2011 | Toshiba Satellite A135-S2276 Notebook
Tip
Resetting the bios password for Toshiba Laptop
It working with the Satellite A135
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back the black lebel back from memory module 1, I soldered PAD500 solder pads (to short circuit them), install one memory memory in slot 2 and turned notebook on, it erase the password and boot without asking for one. Then power off desolder PAD500, replace mylar. Replace memory modules. Replace battery. Power up unit, replace memory cover and screw. Whalá!! the password gone, and you can enter to bios setup to set a new password if you want.
on Mar 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Hi My yahoo mail account has been taken over by someone. How do I retreive it
There is only one way to get yahoo password back and that is by going to the website and clicking on forgot password, after that it will ask you for your security secret questions, if you answer those correct you can reset the password.. good luck
Jun 05, 2010 | Toshiba Satellite A135-S2386 Notebook...
How to removed a toshiba satellite a135-s2276 password from bios
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Dec 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Blank screen asking for password
I presume this is the CMOS or BIOS password.
Turn the unit over and find the ram cover, remove the ram locate the two brass bars near where the ram was. Take a paper clip and bridge them to short out and reset bios password.
replace ram and turn on
please rate our help to keep the FREE service online
Aug 27, 2009 | Toshiba Satellite A135-S2386 Notebook...
How do i perfor a system reset on a toshiba
hi, try this....
the back part of your laptop where your memory card goes to and then remove the memory card look for the word jopen1. you will see a metal letter U and letter T. Use a metal paper clip on the metal letter U and then put the other end of metal paper clip on any metal part of the main board for a few seconds. And then after that put everything back together and see if it works. From there you will be asked for a new password (any password that you would like to use), save and then restart.
note: there's a plastic piece on the metal letters U and T. don't pull it all the way off from it. Hope this will help.
Jun 27, 2009 | Toshiba Satellite A135-S2326 Notebook
Locked out of Toshiba laptop, Help!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Some Toshiba bios passwords can be reset using the Key Disk.exe utility, to do this you need a 1.44Mb floppy disk.
Format the disk to be BOOTABLE using Windows and then with a hex editor, change the first five bytes of the second sector to 4B 45 59 00 00.
Then put the floppy into your machine and boot it up, you’ll be asked for a password, just press Enter. Then when you’re asked to set the password, type Y then Enter, this will get you into the bios configuration where you can then type in a new password.
Mar 26, 2009 | Toshiba Satellite A135 Notebook
How to Reset BIOS Password Toshiba Satellite A135
Hi! In order to reset the BIOS password for your toshiba laptop, you need to bring the NB to the nearest Authorized Service Provider for Toshiba since only a certified Toshiba Technician can reset the BIOS Password. The technician will remove the jumper inside the laptop which is integrated on the motherboard and the BIOS Password will be reset. All issues regarding the BIOS Password are directly handled by Toshiba Authorized Service Provider.
Hope this helps!!!
Thanks
Sep 23, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
