Ricoh sc 681-122 - Office Equipment & Supplies
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press 1 , 0 , 7
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press 1 , 0 , 7
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Sc 395 ricoh aficio 3045
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Jul 05, 2012 | Ricoh Office Equipment & Supplies
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
116 people viewed this question
jasbo
jasbo
