I have a 1EEE 1394 port on my MPC Computer but I can't seem to get it to work or even show up in the device manager.
    Problem Solver:
  • 7 Answers
Are you sure you have it enabled in BIOS
Posted on May 13, 2009
I cant find drive ASUS P5L 1394 Intel 945 Chipset for window 7 , please help me !
If you mean you cant driver or are having problems with drivers
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Jun 28, 2011 | ASUS P5L-VM 1394 Motherboard
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
Im unable to capture video through my firewire
Please reinstall Camera driver and tri agene.
If it’s not working than check your system hardware capability.
Thanks & Regard
Abhay Singh
Oct 12, 2009 | Computers & Internet
No LAN conection displayed in network connections
check that proper driver is installed, in the device manager that shows excmlatory mark that indicates proper driver not been installed, update the driver it will works
Mar 22, 2009 | HP Pavilion a6547c Refurbished AMD Desktop...
Dell Optiplex GX620 will not recognize firewire controller card
1394 drivers should be native to XP, you may be able to correct this by running an SFC scan
Take out the IEEE1394 card
Insert your Windows CD (if you do not have it order a backup from dell)
Exit out of 'install screen'
click Start
click Run
type 'sfc /scannow'
press enter
you should see a progress bar, when finished restart the computer
this compared critical windows files on harddrive vs CD, and replaces missing and corrupt files
Feb 03, 2009 | Dell 2-Port IEEE 1394 FireWire CardBus PC...
General Networking question
lets see here, your NVIDIA thing is for your ethernet port in your computer.
the wireless PCI adapter, is well, a wireless adapter, its used to connect your wireless, and a 1394 Net Adaptor Connection is basically Win2k/XP's way of telling you that you have a Firewire interface installed in your system.
so, if your going wireless, you dont need NVIDIA, and as your device manager shows that it has a red x on it, it shows that its disabled. as for everything else, i wouldent worry about it.
May 08, 2008 | Computers & Internet
1394 Firewire Problem - Locks on Boot-Up When the cable is plugged in
you could try to reseat the card. sometimes the cards don't fit quite right and when you plug in the cable maybe it moves it enough to get a bad connection.
does it post with just the cable pluged in pluged out?
did that help:)
Jan 29, 2008 | ASUS A7V8X Motherboard
USB device ok, but no drive seen
if you have 1394 also know as firewire, use that option. If this is an external hard drive, like what is depicted, than it maybe possible the enclosure has failed.Try testing with other cables or ports.
Oct 18, 2007 | Hitachi TravelStar 80GN 80 GB Hard Drive
Firewire/USB 2.0 both dont work..
Plug in the device( kmake sure hard drive is connected inside) Go to computer management(right click on my computer and select manage) on the left pane select disk management on the right pane you'll see the drives(If a screen pops up saying about initialize disks, then proceed with that) in the right pane if you see any unallocated volumes(big black box, full black) with the same size of your disks then you can right click on em and create a partition! The Create partition comes up and give you options to format and everything, after that completes you'll see the drive in My computer! If you don't see the unallocated drive, then go oer the drive and account for all of em, if there an extra one without a drive letter then that could be your disk! If you have any problems or this isn't the problem, please let me know! regards, babb
Apr 13, 2007 | Vantec 1 Bay NexStar NST-350UF FireWire...
My Camcorder Is Not Detected By The IEEE Card.
1. CHECK CAMCORDER CONNECTIONS AND SETTINGS. 1. The DV Camcorder is turned on and connected by the power adapter (not battery) 2. The Camcorder is in Play Mode. 3. The IEEE 1394 cable is properly connected from you camcorder to the IEEE 1394 card. If you have checked these steps and the camcorder is still not detected, then the camcorder driver is most likely not loaded. 2. CHECK DEVICE MANAGER TO VERIFY THAT CAMCORDER DRIVER IS LOADED. 1. Go to Device Manager by clicking on Programs > Settings > Control Panel > System. (In Windows 2000 you have the additional steps of clicking on Hardware > Device Manager). 2. Under the device heading called Imaging Devices, you should see a device called "Samsung DV Camera or DV Camcorder". If you have an exclamation point "!" on this device, highlight the device by clicking on it and then click the Remove and Refresh buttons for Windows 98SE and ME. For Windows 2000, click on the uninstall icon, then click on the scan for new hardware icon. Even if the camcorder device does not have an exclamation point "!" on it, you can remove it and reload it. With Windows ME and Windows 2000, and Windows XP, the 1394 camcorder driver is built into the operating system by Microsoft and is already loaded on your system. With Windows 98SE the files are located on the 98SE CD in the Win98 folder. If the device is not listed, please check all of items in step #1 above. If it continues to be a problem, there may be a problem with the: 1. Camcorders firewire port 2. 1394 cable 3. The 1394 host controller card Samsung does not support Firewire Components. You must consult the manufacturer of your Firewire product(s).
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
