Radio shack rf modulator model 15 1214
The RF modulator does not seem to be receiving power. The red light is not on. However when I plug in and unplug the receiver, the red light turns on for a split second. I do not believe this to be a split wire in the cord, as I have TWO modulators that are now doing this.
  • 1779 Answers
SOURCE: need cable connection circuit board for symphonic wf2702 television
I replace just the rf connector. You should be able to pick one up at you local repair center. If you did not damage the tuner which the jack will get solder'd into, you'll be ok.
Posted on Apr 10, 2008
shaggyrat
  • 1224 Answers
SOURCE: Power light just blinks
can you get a signal without box to tv
everythings going hd these days it could be they have it set for an hd
rf's pull there signal from the air and and filters to wear its supposed to go
hd is direct signals
9 times out of 10 the new box in not compatible with tv
or the guy who came in and installed the box did something to your tv and ran away
Posted on May 16, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Can't hook up Magnavox DVD/VCR to TV unless I have a RF modulator
Since I haven't heard back, I must clear my queue - call 1-877-philips for help
Posted on May 30, 2008
  • 6 Answers
SOURCE: great TX no receive
broken wire on mic plug, black wire pin 4 0n mic...doc's cb shop ny
Posted on Aug 19, 2008
ve3wtj
  • 147 Answers
SOURCE: do i need an rf modulator to install cyberhome dvd player to hd receiver?
Probably. I recommend posting a photo of the back of each unit. If the DT HD box only has an F coax connector for an aerial input, then yes, you'll need a modulator.
Posted on Nov 11, 2008
Transmits and receives no modulation out
I am not an expert but I think there can be little or no modulation of the carrier wave unless there is an audio input to the modulator. Like any audio amplifier a transmitter modulator (amplitude modulation) is quiescent without an input.
If the modulation amplifier and audio pre-amp are working and modulating the carrier wave and the antenna is ok then audio modulated radio frequency must be being transmitted.
It would be an extremely good quality CB that had a modulation meter. Mostly all they have is a meter giving an indication of the rf power being sent to the antenna and that rf (radio frequency) power would be the same whether modulated or unmodulated.
The modulation envelope, incidentally, is traditionally viewed or measured with an oscilloscope.
The indicated rf power could be verified using a field strength meter but the only practical way to discover if a standard CB is transmitting modulated rf is to listen to the transmission on a suitable receiver. If the squelch is turned down it will be obvious if the rf carrier wave is being received as the hiss would be silenced. If no audio is received it can be assumed none is being transmitted.
I suggest you try another microphone and lead and if that doesn't work it is clearly a job for a repair shop.
Oct 28, 2015 | Radio Communications
Own Atari 2600. Atari not responding to television. (FUZZY SCREEN) One of three problems: 1. I AM NOT CONNECTING SYSTEM CORRECTLY TO TV. please instruct me how. parts i have are: Radio...
Hello!
When powering the stuff there should be light indicated that there is a power on it. how ever if these not been observed, power adapter maybe busted. try to fix it or replace it. Please refer to the atari manual for the correct operation of your stuff.
hpe this help,
melnavz
Mar 14, 2008 | Video Game Consoles & Games
Tip
What to do if your TV won't take your Video/Audio cables
see, your DVD/Video device, outputs Composite Video & and an Audio signal, subsequently you must have AV inputs on your set they are Red & White (Audio) & Yellow (Video) RCA Jacks. If you do not have these then you are a bit stumped. You may however get a RF Modulator, this takes the Composite Video & Audio signal, and converts it into a TV Signal that can be "Received" on a TV Channels.
I have included a link so you understand what I am talking about.
http://cgi.ebay.com/Radio-Shack-RF-Modulator-Model-15-1214-PLUS-AV-Cables_W0QQitemZ300395036829QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45f0f0809d#ht_500wt_1156
on Feb 13, 2010 | Audio Players & Recorders
Can't find where to connect for dvd. no white,yellow,or red plug.
Hello, Thank you for the opportunity to help
Sounds like you got a pretty old tv there, its frustrating not to see the RED/WHT/YELLOW plugs on it. This is because this tv was made when that was not out yet. So are you out of luck? No, you ar in luck but it will cost you a little money.
You can purchase one of these RF modulators at Radio shack for like $29.95.
OR
If you have a VCR, Generally they have these plugs out the back of them you would plug the DVD into the VCR in the Video IN. You're TV will need to be on channel 3 or 4 (dending on your vcr) You vcr will need to be powered ON then tuned to VIDEO INPUT. You can do this by using the remote's up/Down channels buttons or pressing input on the remote depending on the VCR.
The VCR will need to be connected to the TV's coaxe port on the back, That port looks like this:
If you do not have a VCR you would purchase a RF modulator you TV will need to be on channel 3! The modulator is connect to the port pictured above above. The DVD is then introduced to the ports on the back of the modulator witch looks like this:
rulds2008_40.jpg WE hope you found this Very Helpful. This was answered by a human being, That works hard answering FREE questions just for a Thank You!
Regards,
Rulds2008 "ED"
Jan 27, 2011 | Zenith Z19A11S TV
Need the wiring diagram for the 2009 Toyota Corolla
standard radio--------------------
Battery LIGHT BLUE (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna TAN (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) VIOLET
RF Speaker (+) LIGHT GREEN
RF Speaker (-) BLUE
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
Dec 12, 2010 | Car Audio & Video
Old TV. Model M79R. How do I connect a DVD player (only a player). The TV is connected to satellite signal (Dish) wired to the 2 UHF screws. I am not sure what or where to connect from the DVD player.
Your DVD outputs composite Video & and an Audio signal, subsequently you must have AV inputs on your set they are Red & White (Audio) & Yellow (Video) RCA Jacks. If you do not have these then you are a bit stumped. You may however get a RF Modulator, this takes the Composite Video & Audio signal, and converts it into a TV Signal that can be "Received" on a TV Channels.
Feb 13, 2010 | Televison & Video
Connect magnavox dvd to ge tv HELP!
You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
Cheers ... Best wishes
Jan 30, 2009 | Televison & Video
On my new magnavox zv450mw8a i cannot get the vcr to come through the tv. i have followed the instructions on page 20 in the owners manual.what am i doing wrong?
I had the same problem with the dvd/vcr and my tv not communicating with each other even though they were plugged up correctly. I called the manufacturer phone # on the instruction manual. What they told me to do is strange, but it worked. They said to switch the bottom "in" yellow connector to the bottom "out".....and plug the bottom "out" yellow connector into the bottom "in". It worked on mine. Hope this helps.
Sep 22, 2008 | Televison & Video
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Electro Med Services...
