Question about Garden
Transmission stops pulling when it gets hot
Ive got a husqvarna rider 1200 mower witht he hydrostatic trans. after running for a while (15-20 min) the transmission starts shimmying in the pedal, and stops pulling. After i let it coll down for a few minutes, it will run fine until it heats up again. any suggestions?
  • bowhunter112 May 10, 2009
    I changed the oil a couple of days ago, but no change. It never ran low on oil, always had plenty in the reservior.
  • 351 Answers
When was the last time you had the trans serviced?
It could be seizing up from the lack of oil
Posted on May 09, 2009
Hydrostatic transmission in YTH2348 is very weak, pulls intermittently then stops. I changed the oil put 50wt in it, still doesn't work.
hydrostatics will not work with gear oil they take transmission fluid . or hydraulic fluid check with a dealer or read you manual
Sep 15, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a husqvarna rider 155, the transmission loses power after I have ben mowing for an hour
Hi, remove the battery and battery carrier, clean all grass and debris from the hydrostatic drive, cooling fins and fan. Your problem is most likely the hydrostatic drive over heating. Hope this helps, regards Phil.
Jul 04, 2011 | Husqvarna Garden
The back wheels want go cause somethings locked how do i fix that?
the hydrostatic transmission has failed. about 1200 for a new one and the mower is only worth 250 running. sell the mower AS IS on eBay and buy a new one.
Mar 17, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
The mower gets slower and slower and then stops moving completely. I turn it off for five or ten minutes and it's okay ... occuring more frequently ....
The hydrostat transmission is low on fluid. Check your manual, some of these can be filled...most cannot. If yours can't be filled/doesn't have a fill opening, Husq is going to recommend to replace the transmission (sealed unit). There has been limited success by trying to top off the trans thru the vent tube. This is not a Husq approved repair, and is very slow and tedious. But it is a lot less expensive. Good luck!
Aug 23, 2010 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
Countrax C600H When pulling away at highest engine revs the gear box make a werring noise which fades away once i get to speed. Is this something to worry about. Does not happen if speed is built up...
Most likely it is nothing to worry about, just pull off slow. I take it is a hydrostatic transmission? Fluid level for a hydrostatic has to be checked at a small engine repair/deal shop. I have noted that when transmissions go bad the whirring noise becomes signifantly louder, but some whir is normal.
Jun 22, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Hydrostat trans starting to make moaning noise stops pulling
it may be full of dirt etc and has soaked up most of the oil inside the case, if the axle seals are worn and the selector shaft seal is worn I would say that is the problem, if that is the case you may be up for a new trans as I have done a transaxle just recently and the damage inside was extensive and expensive.
you will have to remove the trans and seperate the trans case for inspection
Hope this helps
May 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Change hydrostatic transmission oil
we have tractors and, yes any of those drain bolts will work (for best results do both) then after its drained, put the drain bolts back in and top up the level
Oct 27, 2008 | Husqvarna Garden
Garden Logo
775 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
