Question about Mtd 22" Yard Machine Push Mower
Lawn mower motor just stalls for no reason
I can start it up cold and it purrs like a kitter. i can mow for awhile and it just starts spitting, sputtering and if i can get the mower blades stopped in time it will sometimes recover and sometimes it just stalls and it takes a good 1/2 to start again??? it may do this 10 times each time i use it. i mow about 1 acre with it. MTD Yard Machine 18hp Briggs & Stratton engine. Can anyone help?
  • Anonymous May 12, 2009
    I have the same problem. Just emptied the gas tank and bought brand new gas, put it in and same problem. I can get it started and then it stalls immediately. I checked the air filter, too.
Check for water in gas tank and filter.
Posted on May 09, 2009
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Jul 13, 2013 | Electric Lawn Mower
Mower starts but if it stops then it will not start for the rest of the day????
Mowing the lawn is a necessary chore throughout the growing season. It prevents your landscape from looking unkempt and keeps your home looking nice and neat. How well your lawnmower works can make a huge difference in how you perceive this task. If the mower runs well and does what it is supposed to, then the job might not seem too onerous, but if your mower stops every time it gets hot, then it can turn a job that should only take a little while into an all-day affair. There are a few reasons why your lawnmower might stall after warming up
Jul 29, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Hope this isn't a double post. Yardman push lawn mower rear bag starts right up and then mows about 6 rows before stopping. I start it again and it mows about a row and stalls. I let it sit for about an...
it sounds like you may have a vapor lock on your fuel tank   there should be a diaphragm on the inside of the fuel cap  that lets air in but not out   it may have an air hole clogged  take the cap apart if you can and clean it real good and put it back together   if that is not it  then the float in your tank may be stuck   or a fuel line filter may be clogged
Nov 07, 2009 | Toro Lawn Mower With Toro Power Tools
Engins starts and runs when mowing will backfire and stall.
I am not sure what time of lawn mower this is, but if the blade is directly tied to the motor, usually the belt will just slip if not, but if this is directly connected to motor, it might have jumped timing. If this is not the case, inspect under the mower deck, and determine if there is something jamming the blades against the deck or if their is something bound around the blade, this can cause more strain on the motor, which could result in the symptoms your experiencing.
Aug 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower will not stay running
Sounds like a lack of fuel. If it has a briggs motor replace fuel pump diaphram in carb.
Jul 19, 2008 | Electrical Supplies
Mtd 22" Yard Machine Push Mower Logo
1,407 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
