Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fi code washer wont stop beeping
Dishwasher wont stop beeping and it says F1 on the led display screen! HELP!!!!!
    President:
  • 272 Answers
See this site for a full explanation of how to fix this problem, I don't want to type it alll again. F1 error code is 'overfill' most frequently due to a clogged drainhose. If not see here;
http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm
Posted on May 09, 2009
Our 2 draw dishwasher stops mid cycle once or sometimes several times. The red light comes on and it bleeps until we press the start button then it will continues the cycle.
The red light and beeping indicates a fault. The fault code number will be indicated in the display or by other LEDs being lit. If you post back with the details of the display we may be able to help you.
Jan 25, 2015 | Fisher and Paykel Dishwashers
Washer is showing E12 error. Help
Hello.
This code means an error code. That the dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
· Press "Stop/Clear" to clear the display and stop the beeping if any.
· Reprogram the dishwasher.
· If the code still displays, turn off the power to the dishwasher at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on.
Thanks for using fixya
Aug 02, 2011 | Bosch Nexxt 300 Series WFMC2201UC
F1 code coming up on my Oasis HE washer
YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
My fisher paykel nautlis dishwaher display error code F1
What is the Model #? If both drawers, if a double, display F1 and won't shut-up then the flood switch is tripped and you have to unplug it to keep it from beeping and the drain motor running. The causes for the F1 fault can be numerous but not excluding bad lid lifts, broken link support, cracked drain line and wrong soap. Call F/P
Jul 19, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
My dish washer has a f1 code i put to much
f1 code indicates a leak.open bottom drawer,find the spring clips on side of tub where tub meets the front panel.push the clip and you will be able to slide the track back and remove tub. put tub on floor to left you should see a puddle,dry it up should be ok. Sensor is sensitive to moisture allow 24 hrs to reset if all visible water has been dried up. hope this helps ,please rate my solution :)
Jun 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Sep 24, 2007 | Crosley CE35111AA Electric Kitchen Range
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
699 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
