Question about Quasar SP-2723 27" TV
Game guard for quasar tv
My son put in a code and forgot what four digit number he put in i unplugged the tv i turn it off i still cannot operate the normal functions he is crying his eyes out because he cant operate the dvd help    quasar tv
  • auntysister Oct 13, 2007
    Who is the qualified technicians, and how
    does the TV get re-set?
  • 790 Answers
Ok you need to factory settings to comeback the normal operation of your TV! go to qulified technician to re settings the TV! thanks! i hope this can help to you as solved!
Posted on Oct 11, 2007
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 13, 2007
    you can get a qualified technician at this link: www.fixya.com  you can see the Repair Service then salect a repair man near you! i hope this is a helpful advice to you! thanks and god bless you!
I bought a JVC Screen 48inch used now I am locked out of sound on menu sound like treble and bass is dull how can I get code to unlock I need to unlock code to a used Jvc tv so I ca hear sound, sound on...
Hello
To set Lock and unlock proceeding are give here:
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes
pre-set with a lock code of "0000". You may change the code to any four-digit number you
wish. To change the lock code, follow the steps below.
Press the MENU button
Press [UP/Down] button to SET LOCK CODE.
Press [=> / <=] buttons to operate [lock icon appears]
Press ZERO to acess the lock code. The first digit will be highligted.
Press [ => / <=] button to select the number.
Press [Up/Down] button to move the next digit and continue to follow these directions for all the four digits.
Press OK button to finish.
Press the menu button when finished
DO THIS AFTER UNPLUG THE TV FROM AC MAINS WALL SOCKET, AND LEAVE IT FOR ABOUT 30 MINUTES OR SO, REPLUG IT TO ac MAINS, AND DO ALL THE ABOVE SAID PROCEEDINGS. THIS PROCESS WILL ERASE ALL THE V-VHIP CODES, IF SET, AND WILL ALLOW YOU TO SET AN OTHER OF YOUR OWN. The default V-Chip code is [0000]. Ok.
Apr 24, 2011 | JVC Televison & Video
Vchip reset? Inputs won't show HDMI input option. Floor model TV model# av-48P786 sn#13090154
Hello
If a power interruption occured to your household power supply, V-Chip has to be resetted. To reset the V-Chip do the following.
preset with a lock code of "0000". You may change the code to any four-digit number you wish.
To SET LOCK CODE use UP/DOWN buttons.
To operate (lock icon appeares on pressing =>/ Press ZERO to access the lock code
The first digit will be highlighted
Use =>/<= button to
To select the number
Press Up/Down button to
To move to the next digit
Continue to follow these directions for all four numbers
Press the OK button to finish (your lock code is now set)
Press the Menu button when finished
OK. Thanks for using Fixya.
Apr 07, 2011 | JVC Televison & Video
How can i find remote control codes for my quasar tv
Hello
Three digit universal remote codes for Quasar TV are:
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit univeral remote codes for Quasar TV are:
0171 0148 0054 0170 0062 0374 0381 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. NB: Switch OFF and switch ON your TV, WITH ITS FRONT PANEL POWER CONTROL SWITCH, each time before trying an other code.
OK.
Feb 23, 2011 | Quasar VV-1301 13 in. Combo
Hi lt40fh jvc how do i get the channel locks off please
Hello
If you forget the Lock Code, a new code may be set using the steps listed below.
After a power interruption you must reset the Lock Code
Channel Guard and V-Chip settings are protected by a four-digit Lock Code. Your TV comes pre-set
with a Lock Code of "0000". You may change the code to any four-digit number you wish. To
change the Lock Code, follow these steps
Press "UP" or "DOWN" button RESET LOCK CODE
Press RIGHT or LEFT button to operate
The Lcck Icon appears.
Press ZERO to access the Lock Code
Press RIGHT or LEFT button to seelct the number.
Press UP or DOWN BUTTON to move to the next digit
Press UP or DOWN button To FINISH
Press RIGHT or LEFT button to save settings and exit
Your new Lock Code is now set.
OK.
Dec 28, 2010 | JVC AV-27230 27" TV
What is the TV Code for programming the remote control for Quasar TV model # v v 2018 w ? Thank you.
Hello
Four digit universal remote control codes for Quasar Tv are:-
Three digit universal remote codes for Quasar TV are:-
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
OK.
Dec 08, 2010 | Quasar Televison & Video
What is the Quasar TV code when using a Direct tv REMOTE?
Hello
There is only one four digit remote code for Quasar TV with me. Here it is. You just try. Proceedings are also given. Ok.
[0716]
Proceedings
Oct 24, 2010 | Quasar SP-3232 32" TV
Tv is locked how to unlock no code
Hi mark
To answer your question;
Try to hold the "action" and "power" buttons at the same time for more than 10 secs.
Another one is:If you can get into the menu under "game guard" there might be a lock code , try 333
This works on panasonic tv of the same model, but then quasar is panasonic.
Don`t forget to rate this answer if its helpful
May 19, 2010 | Quasar SP-3233 TV
Need tv code for Quasar LSSQ0227 its a comcast
had this problem myself and I assure you that a) Comcast is populated by idiots without training, and b) that Quasar hasn't 'deliberately designed' their tvs to not work with Comcast remotes, which is what Comcast will tell you.
Solution: Add a 1 to the code, ie 10250, 10051 etc. Quasar is a 5 digit code, not 4 as Comcast believes.
Feb 06, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
Unlock game guard
how do u reset gameguard i accidentally blocked it plz help i wann play MS so bad
Oct 18, 2007 | Quasar SP-2723 27" TV
hold power and action down ten seconds
Oct 11, 2007 | Quasar SP-2723 27" TV
Quasar SP-2723 27" TV Logo
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
