Question about Sony Car Audio & Video
I want to take out factory radio to install stereo
I bought a car stereo an want to take out factory radio but i don't know what wires are what.
  • 1,305 Answers
Stereo dealers have wire harness adapters for almost every make and model of car. It will come with a connector both with color coded pigtails that are usually prestripped. The package will described which wires go where and their color codes. The deck you bought should have a pigtail with color coded wires and they'll match up to the ones on the harness adapter for your car.
After connecting them all properly, you can take your deck with the attached pigtail and plug adapter and plug it directly into your car stereo plug where your old radio was connected...don't forget the anntenna lead as well... Not to difficult...email if you get stuck...
KEN
Posted on May 09, 2009
How can i replace 1991 maxima radio system?
The original radio is a BOSE system and it has a buit in amp. So if you replaced the deck you need to replace the speakers all so. Don't cut the wires to hook-up the deck buy an addapter KIT. It's not just the stereo that runs though that harness the factory alarm does all so and that will cause you problems. Anyway back to the stereo you need to add an amplifier and problem sovled.
Jul 23, 2012 | 1991 Nissan Maxima
Hello I just bought a new stereo for my mitsubishi galant 2002 but i need to know the wiring diagram in order to make the installation if anyone can help thanks
Wiring adapters are available for nearly every make of vehicle, which allows you to plug right in to the original radio connectors. They come with wiring diagrams, and are nearly idiot proof. They cost usually about 10 to 15 dollars, and are available just about anywhere that sells car stereos. This also allows you to reinstall the factory radio when it comes time to sell the car and you want to keep your stereo.
Sep 05, 2011 | 2002 Mitsubishi Galant
Replacing radio with an after market cd player in a 1999 ford au sedan jjust need to know what color wires what on the car
  • You did not list the model of Ford Sedan you are inquiring about. Here is a link that has quite a lot or car stereo wiring diagrams http://www.modifiedlife.com/request-a-ford-car-radio-stereo-wiring-diagram/ Look at the upper right of the page and scroll down a little bit as I have it on Ford vehicles already. Find the make and go to the year.
  • That being said if I can make a suggestion. I have hooked up hundreds of car stereos in my life. When I pull a factory radio I don't use the same wires that powered that factory stereo to power the after market stereos, DVD players etc. I go into the dash and find suitable wires a little thicker gauge to handle to often more powerful output of the aftermarket stereos.
Regards, Tony
May 20, 2011 | Car Audio & Video
New Car Radio, New Harness but no power, Nissan P/U '95
here is the factory harness wires and what they do, recheck thayt it all matches up.
1995 Nissan Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Mar 10, 2009 | 1995 Nissan Pickup
2005 town and country factory stereo removal
It's actually not too hard when you figure everything out. I just installed an aftermarket stereo and couldn't get any sound until I stumbled across a solution on this site. First you need to get the correct wire harness which I bought on ebay for $1.99. Then you need to get the install kit. I got mine at Radio Shack for $10.00 cause they're going out of business. You can get it at Best Buy too or any other car stereo place. To get the old stereo out. Take out the cup holder. There is a button on the top rear of it that releases it. Then remove the 2 screws at the bottom. Gently pull the entire trim that surrounds the stereo, cd changer and ac controls. You will now have access to removing the stereo. It's very easy after that. After you connect the wire harness and install the new stereo you need to run a wire from the red ACC wire on the stereo to the NBS relay in the fuse box under the hood. That's it! Good luck. Sorry I have no pictures.
Feb 12, 2009 | 2001 Chrysler Town & Country
04 trailblazer radio (Replacing factory with another factory)
take vehicle to local chevy dealer and have radio unlocked,only option
Jan 21, 2009 | 2004 GMC Sierra Denali
Want to replace factory radio
go to walmart find your cd player, dash kit ,wiring kit and then this is what you do .. remove the old radio attach the wiring harnes you bought to the factory wiring harnes this will allow you to match the color code up for your new radio with out cuting wires then install the new dash kit witch will allow you to install your cd player with a factory look this should be everything ou need to know
Dec 04, 2008 | 1995 Oldsmobile Eighty Eight
Installed a clarion radio it powers up but no music thru speakers
sounds like a short in your wiring to your speakers the best thing to do to check this is run a speaker wire directly to the speaker from the stereo check it that way and see if it works.If that don't work it's the wires on the stereo connection.The speaker wires on most aftermarket stereos are mostly colored 2 of each green,purple,white & grey.
Nov 09, 2008 | Clarion DB538RMP CD Player
Car Audio & Video Logo
232 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
