Question about ASUS Tablets & eReaders
Asus tab k004 not switchin on
The battery of my tablet was drained and switch off but as i start to charge and switch it on the tablet is not reponding and i try many time to switch on but still no responce on it.i tried to charge for half day and coming an indication of battery but not charging.
  • 44 Answers
SOURCE: Battery is not charging
Let the battery go all the way dead. You may have to adjust the settings in your bios so that the laptop will stay on until the battery goes completely dead. Then charge the battery. Do this a few times if it does not fix the problem you do need a new battery.
Posted on Jan 21, 2008
  • 72 Answers
SOURCE: My Gateway m275 tablet will not charge or power up even with it plugged in
At least a 50% chance the power pin inside the computer has been damaged. Taking apart a laptop and getting it back together correctly is a tough job . . . .The part (the power pin) is not that expensive ($ 5-10) but the labor is expensive. If you don;t feel up to the task, have it fixed by a professional and after it''s fixed get a CRD (Cable Retention Device) to keep from damaging the pin a second time.
Posted on Aug 26, 2008
  • 417 Answers
SOURCE: battery fails to charge completely
It sounds to me as if your battery is faulty. No way should it take 17 hours to charge. The battery is abviously not absorbing the charge and this could be because one or more cells are defunct. You can just wait until it fails completely or look at getting a replacement before this happens.
Please remember to rate this solution.
Posted on Nov 02, 2008
SOURCE: Power port on le1600 does not charge batteries.
We contacted Motion about an issue with our docking station because our power & USB ports stopped working, or worked only intermittently. We were instructed to remove the front cover from the docking station to check the connection of the cables. We found that the cable had completely disconnected (it had evidently pulled loose from tilting the dock up and down). Once the cable was reattached, and the cover reassembled, viola! Success!
Posted on Nov 23, 2009
senate42000
SOURCE: My VIZIO Tablet 1008 micro USB charging port is looseand charging indicator comes on some times when I move the wires around. ow do I get to charge the Vtab?
I had the same problem with my vizio tablet. The port came loose after the wife and kids kept playing with it. The tablet would not charge anymore. What I had to do was open the tablet and check if the little pins that connect the Micro USB port were still soldered on the circuit board. Mine were broken off so I had to replace the whole port. I couldnt even find the OEM replacement part so I had to buy a Mico USB (style B) port off ebay and made it work.
Posted on Jul 03, 2012
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
How do i get my asus tablett out of frozen
Assuming the restart option isn't available after pressing and holding the start button for a few seconds; you can let the battery drain ... but it may take a few hours. (Adapter must be unplugged). Then connect the adapter and restart. Another way is to remove the battery.
After the tab restarts check if system updates are taken care of. If the problem happens because of a particular app consider to uninstall that app.
Feb 17, 2015 | ASUS MeMO Pad HD 7
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
Jul 20, 2014 | ASUS MeMO Pad HD 7
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
My asus memo 7 inch tablet won't power up
This is a common problem with Asus devices. If the battery has drained completely, they don't like to come back to life.
Plug it in and leave it for a minute or so. Unplug the device, replug it, and hit the power button. The battery logo should appear, indicating that the device is powered off and connected to a charger. Now that the computer is awake (to display the message), hold the power button until the device powers up. You may have to hold the button down for up to 45 seconds.
Mar 31, 2014 | ASUS MeMO Pad ME172V-A1-PK 7-Inch 16 GB...
T wnt charge it starts to but then blinks off
battery! I had to switch to using the original charger a few times or it would not charge and then I could go back to using any USB port to charge it.
Feb 23, 2014 | Samsung Galaxy Tab Tablet PC
My Asus tf300t tablet is fully charged but now it won't switch on, what do I do? Help!!??
Keep "Power" button pressed for 15 seconds and then release it. Or you can try a "cold reboot": Keep "Power" and "Volume down" buttons pressed until you can see two icons on screen, then release both and the tablet will boot.
Oct 06, 2013 | ASUS TF600T Vivo Tab RT 32GB 3G with...
THE TABLET BATTERY DRAINED DEAD NOW IT WONT POWER UP WITH THE CORD OR BATTERY DEAD. IS IT THE BATTERY OR CORD THE PROBLEM. MY OTHER LAPTPS WILL STILL POWER UP IF THE BAT IS DEAD, IS THIS NOT TRUE FOR THE...
Have the power adaptor checked by an electrician, most probably you will need a replacement.
If you establish that the adaptor is working, then something happened to the battery charging circuitry in your Asus and it will need repair.
If it's still under warranty, then you are good, otherwise it would be better if the adaptor alone failed, as replacement adaptors are rather inexpensive compared to laptop repairs.
Dec 31, 2009 | ASUS R1E-B1 Tablet PC
Tablets & eReaders Logo
99 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
