Question about Bosch Evolution 300 SHE33M05UC Stainless Steel Built-in Dishwasher
Can not open dishwasher door
My blonde sister just bought a new SHE33M dishwasher....she ran wash cyle ....the clean light came one, but she can not open the door.
Please help....she tried to cancel the cycle, but that didn't work...so now she's mad because she has a new dishwasher and dirty dishes from dinner....plus she has to work tomorrow. This is not a joke. thank you...
  • shirlock1950 May 09, 2009
    my sister said that the child lock is not on.....she now thinks that it's too tight a fit under the counter....her very handy Andy boyfriend is there and that's what he thinks it is because the counter is a little warped... plumber is coming back in the a.m. to look at it....so time will tell.
    Sniper:
  • 75 Answers
Is the child safety lock to the left or right? (its located in a recessed space where the main handle is) if its to the left then its locked and will need to use something like a matchstick inserted in the small hole next to the switch to deactivate it.
Posted on May 09, 2009
  • Shannon Greer
    Shannon Greer May 09, 2009
    is the child lock activated? its located in the recess of the door handle. if the small switch is to the left then its activated and you will need to stick something small like a matchstick into the small hole to release it and push it to the right
  • Shannon Greer
    Shannon Greer May 12, 2009
    thanks for the innapropriate rating! why not a thanks for trying? was it the counter?
The dishwasher is staying in the washing cycle
LG14AW2 DISH WASHWER STARTED AND RAN YESTERDAY , STARTED IT TODAY , WENT TO WASH CYLE AND STAYED ON THAT . TURNED IT AND TRIED TO RETART IT ,ALL THE LIGHTS LIGHT UP BUT NO GO . HAVE CHECKED THE DRAIN HOUSE ,ALL OK ,FITTED NEW PUMP . AND STILL DOES THE Same thing , whaat do i do next to fix this dam thing
Aug 11, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Normal and heavy cyle lights wont come onwhen selected What is happening?
do you get 7 flashes of the clean light? if so, do this: Open door press: high temp, energy save, high temp, energy save, close door, open door, press cancel. then run as usual.
Jan 15, 2011 | KitchenAid 24 in. KUDP02FR Built-in...
Bllinking "clean" and cant start a new load? Need to reset? How to reset?
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 08, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Clean light is flashing and dishwasher won't turn
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Thanks
Rylee
Oct 22, 2009 | Kenmore Dishwashers
K-more elite dishwasher stuck in sensing mode; won't move to wash
Where did you find the sequence to clear the flashing clean light?
Apr 14, 2009 | Kenmore Dishwashers
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore elete dishwasher flashing light clean
-high temp wash
-heated dry
-high temp wash
-heated dry
Dec 06, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Whirlpool gu2400 dishwasher
-high temp wash
-heated dry
-high temp wash
-heated dry
Dec 05, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
-high temp wash
-heated dry
-high temp wash
-heated dry
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Bosch Evolution 300 SHE33M05UC Stainless Steel Built-in Dishwasher Logo
447 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
