Question about Wolfgang Puck BDRC0010 10-Cup Rice Cooker
Replacement parts Need to replace insert basket the non stick coming out
Where can I buy new loading baskets for my DWI 160 dishwasher?
These come as several parts. Not sure if all are available anymore as Candy parts. But you can get replacement Hoover parts to fit.
Main basket from Candy
Candy DWI 160W UK Dishwasher Basket
Cutlery basket from Candy
Candy DWI 160W UK Universal Cutlery Basket
The Upper and Lower baskets may not be available from Candy but Hoover replacements are
Candy Use HVR41022779 Lower Basket
Best to ask Candy support to provide pictures of the parts for comparison with your model or purchase or a refund policy if not suitable.
There is another site worth checking (but prices seem high)
CANDY DISHWASHER BASKET LOWER for DWI160W UK
Sep 23, 2014 | Candy Dishwashers
My daughter stuck 13 popsicle sticks im my sons ps3, now it won't take disks, can irepair this, if so how much?
You're most likely going to have to send the PS3 into sony for repair. If the unit is still under warranty, you might be able to get it fixed. But I highly doubt the warranty covers insertion of popsicle sticks into the console. The costs could range from replacing the unit tto being charged for parts and labor. Shipping is generally the customers (your) responsibility. Factor about $10-25 for shipping, plus insurance. Nor sure what Sony will cost to repair the ps3 though. Worse comes to worse, you'll have to replace the unit all together. The ps3 doesn't use a disk tray, so it's not as easy as simply replacing that. Damage to the lens could be possible as well. I'd ballpark your repair cost from at least $100 to full replacement cost of a new ps3 (todays prices for an 80gb is like $199, anything bigger is generally $299 and up).
Dec 05, 2010 | Major 320GB Playstation 3 PS3 Upgrade Kit...
1998 Lincoln Continental fuel tank. The basket
Hello drahos376. My Name is Roger and I will help. If the component you are asking about was located inside of the fuel tank? The parts inside the tank such as the baffles and the cup the fuel strainer sit in are non replaceable. There would be no way to open the tank to install them. I would check with a salvage yard to find a replacement. A new tank from the dealer is very expensive to buy. Should you need further help lease just ask. Please rate the answer that you received as this way I know it helped. Thank You for using Fix Ya. Roger
Jun 19, 2010 | Lincoln Continental Cars & Trucks
Replacement fabric basket
You will be able to buy the parts you want from www.buggypitstop.co.uk
Jan 01, 2010 | Mountain Buggy Urban Single Stroller
Slipping clutch
clutch basketYou will need the fibre clutch plates and I would be replacing the clutch springs because the 400 had weeker springs than the 450 (04YM). Also check if the metal plates are blue this is a sign they are bernt and they may need replacing if it has been slipping for a period of time. Use 10w 40 oil. Motul or Motoex oil they are good and go genuine some non genuine plates can swell and cause drag. Sometimes the basket may have small wear marks on the fingers. If it has you can clean them up with a file but dont take to much off. The only other reason you would replace the basket is if the damper rubbers between the basket and big gear are worn.Try and move the gear and hold the basket, if the gear moves the dampers are worn and need replacing, I think you can get the dampers seperate. If you go to a good Gas Gas dealer you wont get riped off, I would take your plates in and ask for the mechanic for advice and not the parts person.,,,
Nov 10, 2008 | 2003 Gas Gas EC 400 FSE
Non-Stick Surface is coming off
I do believe that you can contact the distributor in your area, or you can contact the manufacturer directly in Europe that will forward you to the nearest part supplier, do not forget to tell them where you live (city is enought) you have their contact in their webpage www.flama.pt .
PC
Jan 22, 2008 | Flama G1600 Indoor Grill
Bottom plate replacment
theres lots of posts here regarding george foreman products.
there does,nt seem to be anywhere to buy replacement parts.
I,d suggest buying a new alternative product, with a more stable background, and reliable service and replacement parts. i.e russel hobbs or tefal et,c.
Mike @ Compurepair.
Jan 08, 2008 | George Foreman GR30 Indoor Grill
Wolfgang Puck BDRC0010 10-Cup Rice Cooker Logo
Top Wolfgang Puck Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
eyecam
Are you a Wolfgang Puck Kitchen Appliances - Other Expert? Answer questions, earn points and help others
