Question about Garden
028 av wood boss choke diagram - Garden
3 Suggested Answers
  • 4 Answers
SOURCE: Chainsaw wen warms up bogs down, wants to die cutting into wood
Could be running too lean, Should be runnning 50:1.
Posted on May 23, 2009
  • 6468 Answers
SOURCE: my stihl 028 super wood boss wont start
is it getting gas?is the fuel filter plugged?does it kick if you drop some fuel into the carb?
Posted on Mar 26, 2012
Stihl 028 wood boss av carb wont prime
Remove the primer plate, you will see small orifice on side opposite the bulb, blow compressed air through this toeard bulb side. This is check valve that becomes plugged quite often. Now blow all other orifices gently to prevent damage.
Sep 10, 2017 | Stihl Garden
How do you remove the thermostat from a 93 Polaris trail boss 350L 4x4
DOWNLOAD POLARIS TRAIL BOSS REPAIR MANUAL
trailboss-manual.blogspot.com/
Nov 5, 2014 - 4x4 free printable 1989 polaris trail boss 350 2x4 parts 03 polaris 350trail ... engine diagram trail boss 350 4 stroke diagram how to test the thermostat ... apolaris trail boss 1994 350 shop manual for 1993 polaris 4x4 trail boss ... boss 350oil pump repair manual for polaris trail boss 1987 removing jets in ...
Sep 25, 2015 | ATVs
I have an old 028 stihl av super electrical quickstop have rebuilt the carb on it put new gas new spark plug is turning over but not starting please help Dan from NY
due to age , id start by seeing if it has any spark in plug , remove plug wire and insert 1/4 bolt , arrange near by a metal bolt or other item (not handle ) and do not hold bolt near item
turn ign switch on (don't bother with choke) and pull engine over several times , observe 1/4 bolt for blue sparks (dim lights if necessary )
no spark present , trouble shoot ign system farther
spark present - remove and clean plug with good solvent
add a little bit of engine start fluid to plug hole and reinstall plug and wire , attempt to start engine , nothing - compession problem or shorted plug if it sputters but doesn't start then its a carb problem , troubleshoot carb (clean it )
Apr 14, 2015 | Stihl Garden
Stihl o28av wood boss will not start even after I rebuilt carb
Rebuilding it does not mean it is adjusted correctly but if you are confident with that I would check for air leaks in the hoses. Replace the spark plug or make sure that there is spark in the existing one. You can test that it will fire with starting fluid then you know that it is not getting the right amount of fuel.
Oct 10, 2012 | Stihl Wood Boss Chainsaw 20"
My stihl 028 super wood boss wont start
Mar 25, 2012 | Garden
Stihl wood boss 024 av electric quick stop manual
There is no way to tell unless I saw a picture of the wiring out of the machine.
Mar 21, 2012 | Stihl Garden
How to install Boss Audio BV10 4FB
Open the packaging and check that these parts are present. Connect the external devices RCA cable or AV output as reguired. Refer to the connection diagram Match the position of installation bracket and installation plate with screw A. Secure the unit in place with the supplied screw B.
see the below link and you will get picture wise explanation and connection diagram details are explained clearly
Aug 19, 2009 | Car Audio & Video
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
