Question about Zebra ZP 450 Thermal Label Printer
Zp 505 installed but not printing with windows 8
Fed Ex supplied a ZP 505 thermal label printer. We installed it on a Samsung PC with Windows 8
5 Suggested Answers
SOURCE: Zebra printer is printing two copies when only 1 is checked
Same problem exactly and was not able to get a response from UPS or the zebra company, someone please help!!!!!!!!!
Posted on Aug 04, 2010
  • 3278 Answers
SOURCE: Hi, I have a zebra
Hello.
Test printing the label on a sheet of paper instead of labels.
Make sure that any "Fit-to-Page" or "Reduce/Enlarge" or "Scale to Fit" setting are disabled in your printer driver. To do this click on Start>Printers and Faxes, select your printer, right click the mouse and click on the Printing Preferences option. You should find the setting in the Effects tab.
Please be more specific about "it will not recognize what to print".
Hope this helps.
Posted on Jul 14, 2011
reyjoshua07
  • 1157 Answers
SOURCE: ZP 500 PLUS /
Hi bruce_woodwa,
Please check if the thermal labels are installed correctly. If you're using a DT mode make sure the drives is setup correctly.
Please follow the steps below on how to install printer labels.
1. Open the printer by applying pressure to the release levers located on the sides of the printer, towards that front. Remove any test bar code labels if present.
2. Move the left media hanger to the side.
3. Position the media roll so that the printing surface faces up as it exits the printer. Place the roll between the hangers and the release the left media hanger to hold the core. Remove the first 2 to 3 labels from the roll.
4. Make sure that the roll is resting on the hangers and that the roll turn freely. The roll must not sit in the bottom of the media compartment.
5. Close the printer cover. Connect the power cord to the printer first and then to the power source ( wall outlet ). Ensure that the labels are installed correctly.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 24, 2011
  • 3 Answers
SOURCE: Can you help me find a Windows 7 driver for my Zebra ZP-550 printer, please?
The Zebra ZP 550 will work with the GK 420t driver which is free for download at zebra.com. After installing it restart shiprush and your zebra printer will show up in your printer selection menu.
Posted on Dec 19, 2012
Numbers are shifting onto THE barcode area
I am having this same issue. prints fine on paper but not on the ZP 450, barcode numbers are printing inside the top half of the barcode.. Any one help?
Mar 06, 2015 | Zebra ZP 450 Thermal Label Printer
Printing white lines on label
Missing elements in print head, replace print head.
Nov 05, 2013 | Zebra ZP 450 Thermal Label Printer
Printing half label width
hold feed button and release during 5 blinking lights. printer will auto set the width. Press feed again once you want the desired width.
If it's actual printer issue, then you have to call service tech.
Sep 23, 2013 | Zebra ZP 450 Thermal Label Printer
Zebra 450 couldn't print full page Photo
please check the drivers megerments regarding papel WxL and Label WxL that u using.
Sep 11, 2013 | Zebra ZP 450 Thermal Label Printer
I have a Zebra ZP 500 plus printer that will not work with UPS online , Is there a way to fix this problem ?
Call 1-800-Pick-UPS It is a conflict on thier site if it is installed and still not working. The service tech should be able to assist you to get the site working with the printer.
Sep 20, 2012 | Zebra Technologies Zp 500 Plus Thermal...
I have a zebra zp 500 plus and it wont work with ups
Ensure its drivers and everything are installed on the machine and you can see it under printers as online. From there Call 1800 Pick UPS and the service tech will assist in getting it up and running with the UPS site. It can be used for UPS from what I am seeing.
Sep 20, 2012 | Zebra Zp 500 Plus Thermal Label Printer
Aug 21, 2012 | Zebra Z Office Equipment & Supplies
I have a Zebra ZP 450 and I use the standard sized UPS labels (4x6). I cannot get the labels lined up properly - that is to say, this printer will always print the address on two separate labels,...
there must be a label gap sensor in there somewhere. see if you can find it in the label path and clean anything you see off of it. does this printer have a calibrate function? if so do that after you clean the sensor. here are the calibration instructions from zebra https://www.zebra.com/us/en/support-downloads/knowledge-articles/zp-series--calibrating-the-printer.html
Jun 01, 2017 | Zebra Office Equipment & Supplies
Mar 19, 2010 | Zebra LP 2844 Thermal Printer
Zebra ZP 450 Thermal Label Printer Logo
445 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
