Question about Drills
Radial drill wiring schematic
Its a NANKING 4th MACHINE WORKS Chinese machine.
Z3035B 3 phase. Its 12 speed and im led to believe its got a 4 speed motor. There is 6 wires comming from the motor with STAR STAR DELTA on the cover plate. The drill was made round mid 70s
deme-tri
  • 90 Answers
SOURCE: Changing voltage on motor...
pull up the i.s. wiring code from that time
i.s. international standards.
the code change a few years ago
Posted on Aug 03, 2009
  • 4088 Answers
SOURCE: 1/3 hp drill press motor runs hot and very slow.
Look instead at the motor and drill post bearings. Remove the belt to see if the motor runs correctly with no load. If it still hums and gets hot, check that the motor itself turns freely (when off). If the motor seems to be ok, turn the driven pulley by hand--it should also turn freely. The capacitor is usually a starting assist, not running. To test, wrap a small rope several turns (when pulled must turn in the normal direction) around the small motor pulley and pull smartly while turning the motor on. If it now comes up to speed, the capacitor has lost capacitance. Electronic parts suppliers like Jameco or Mouser have such items.
Posted on Aug 23, 2009
rowdy45176
  • 2176 Answers
SOURCE: Delta Variable speed drill press will not spin belt freely
I would go to Dewaltservicenet.com and you can download a breakdown and also user manual for this tool with information about the set up and belt assembly, the breakdown would show you how everything is supposed to go in the pulley section. L et me know if you need further help
Posted on Oct 08, 2009
  • 91 Answers
SOURCE: how to wire a 12 wire 3 phase motor without the
You wire it like this:
4 and 7 together
5 and 8 together
6 and 9 together
1 goes to T1
2 goes to T2
3 goes to T3
And if the rotation is wrong, switch any 2 or 1,2,or 3
Now you are going to have to ohm your wires, your lowest ohms of two wires go together. Best thing to do is google delta and ywe transformers...Of course if all else fails take to a motor shop (electric) and they can map it for you.
Posted on Feb 24, 2010
SOURCE: wiring a single phase 14 in fan
hi, i have a ''hunter 23918 classic original which runs suddenly slowly, anyone who can help me out, or can forward me a wire diagram, thanks, from johnbraks.
Posted on Apr 21, 2010
Convert 3 wire plug generator to 4 wire plug cord
First verify that the voltage is the same. It sounds like you have a single phase system which is 2 voltage circuits and 1 neutral. The 4th prong will be the ground. To do this properly you will need to get a new 4-wire chord for the generator with a cap that matches the one for your house. On the Generator side, the 4th wire will attach to ground.
Oct 04, 2017 | Dryers
Dewalt radial arm saw GW1- Is it single phase or 3 phase
if the plug on the cord fits any other outlet in the house it will be single phase
if the cord is cut , then it will have only 3 wires if it is single phase
( active , neutral and ground )
if it has 4 or more wires it will be 3 phase
most saws running a 200 mm blade or around that size and used for home duty will be single phase
the phase notation will be on the plate attached to the motor of the saw
It will read voltage , amperage, watts or hp, phase and cycles
Jan 02, 2016 | Dewalt Saws
Is this ice-cream machine is working at 3-phase power supply
Very unlikely unless it is a Commercial machine. Do you have a Make and Model?
3 Phase would have a large circular plug with three radial contacts and 4 wires.
Aug 14, 2015 | Ice Cream Makers
Hi,need to get a owners manual for a Ryobi RA2500 radial arm saw - can anyone help me?
Ryobi has a nice support site http://manuals.ryobitools.com/documents
with most of their manuals but nothing for a radial arm saw. The 2500 just isn't that common. Here are some schematics:
http://www.toolpartsdirect.com/ryobi-ra2500-radial-arm-saw.html
and here is a recall that was issued a while back
http://www.cpsc.gov/cpscpub/prerel/prhtml06/06212.html
Nov 30, 2014 | Ryobi Drills
How to conect three phase 5 wire conection to 4 wire 380volt three phase from the machine
Identify each of the 5 wires with voltage testing.
Find which breaker serves the 3-wire, and which breaker serves the 2-wire.
--You might have a 3-pole 3-phase breaker (with 3 hot wires) plus a single-pole breaker (with 1 hot and 1 neutral) ... giving a line with 4 hot wires and 1 neutral.
--Or you might have a 3-pole 3-phase breaker (with 3 hot wires) plus double-pole breaker (with 2 Hots) ... giving a line with 5 hot wires and no neutral.
The 4 wires from machine are probably 3 Hots and a neutral, or 3 Hots and a ground.
You need to identify where the ground wire is. One of the 5 wires from breaker box might be a ground.
Copy following links:
http://waterheatertimer.org/How-to-wire-3-phase-electric.html
http://www.electriciantalk.com/f5/
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 05, 2013 | Hardware & Accessories
We just moved and had to change the electrical plug on our dryer. Ours has 3 wires but the new plug we got has 4 wires can we still use it? and if so what do we do with the 4th wire?
You will find the outlet is designed for a 3 phase plug, just wire up the plug as normal with the 3 wires, ignore the 4th pin. Safer to get an electrician to do it for you.
Sep 03, 2012 | Fisher and Paykel DGGX1 Electric Dryer
I have a Drill press 16 Speed, Model BT1001A and the On/Off Switch and light switch has all been removed. How do they go back on the switch and the sequence? How do I get access online to the schematic...
This is a difficult question. There are Euro, American and Chinese motors used, the most common is the chinese one phase motor at 110 volts. This is again complicated by the fact the chinese changed the hookups between 1999 and present models. In 1999 the Grizzly type clones from China had a six screw terminal block with the supply wires being: BLUE, BROWN, BROWN, BLACK, GREEN/YELLOW. with U1=BLUE, V1=BRN, Z1=nil, Z2=BRN, U2=BLK, V2=nil and you could reverse the direction of rotation by reversing the two brown wires on V1 and Z2. The new chineese wiring has made some changes to this and can be viewed on the details of any eBay site selling new Grizzly metal lathes of the 12X36 size of which they make about 9 varieties, keep reviewing each one, there are about two ads that give actual pictures of the new terminal blocks they use which have two flat bar jumpers right in the block and they use different terminals within the six on the motor.
My example is for a 1999 Chineese electric motor for the AT-400 Lathe/Drill/Mill which uses a generic
WANNAN 1 phase electric motor 3/4 HP, 1700 rpm, 11.0 Amps, 110 Volts, Date 99/7
American and Euro wiring tends to have other colors like white, orange, etc. and up to twelve of them so you have to research the exact motor, where it was made, and what date to get the right info. then you have to draw diagrams to match your switch wire hookup to the plate which is on the motor just beside the terminal block. Mine had two reversing switches and two motors plus another switch which selected between power to the mill or power to the lathe. Using the above color codes it worked right the first time only because I researched and then charted out every wire and did continuity testing to ensure functionality without worn-through or loose contacts. Also, unplug the machine and leave unplugged overnight before touching the wires as the capacitors carry a big charge at high voltage and hold it a long time.
Mar 24, 2011 | Clarke Power Products Clarke 16-Speed...
I NEED A WIRING DIAGRAM FOR THE SWITCH ON AMODEL 7191 TYPE 3 , 3/8 B&D DRILL
i don't think you will find a diagram for the switch. find a parts schematic and order a new one. they aren't make to be fixed.
Aug 02, 2010 | Black & Decker 3/8" Variable Speed...
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Drills Logo
249 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
