Question about Dell Inspiron 1720 Notebook
Hi,i have a dell inspiron 1720 lapptop ,i get the error code 2000-0334 when i choose i don t see the colours.my screen is splitted in 4 and i can see the same image 4 times,in the test i can see the c
My screen is devided in 4 ,on diagnostic i can see the colours on full screen .any ideas?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Change your NVDIA card.Change your display card and check again.
Posted on Jun 26, 2014
SOURCE: Dell memory Dimm B errors, 2 gig memory upgrade
I've put my original 256mg card in DIMM A and my 1gig card in DIMM B and have had no additional problems. So I'm just living with 1.25gig of memory...
Posted on Dec 06, 2007
  • 3940 Answers
SOURCE: Dell Inspiron 1420 freeze at starting
This is an easy one.
You hard drive has DIED.
Call or chat with Dell tech support and get a replacement drive
http://support.dell.com/support/topics/global.aspx/support/chat/hardware_chat?c=us&l=en&s=gen
Since the system is less that a year old, you can request a replacement drive witht eh factory image on it too.
Posted on Jul 14, 2008
SOURCE: Dell inspiron 6400 screen problem
I had the same problem. You need a new graphics card.
Posted on Jan 29, 2009
  • 3940 Answers
SOURCE: Dell Inspiron 1526 cannot communicate with battery
The diagnostic Error is a False positive you can ignore the diag error as the LCD is functional. If the battery is not recognized in the BIOS or you get an warning the AC adapter is not recognized, then you may have either a damaged AC adapter sensing pin (Fine wire in middle of ac adapter connection to Laptop) or a problem with the charging unit on the motherboard.
If the sensing pin is damaged or the ac adpater is not sending the right signal to the system, the battery charger will not work. SO if you have another Dell D series AC adapter, you can try it 1st. If the battery is 18 mos to 2 years old, you might see if it is IDs in BIOS and if it indicates battery state. Also the battery should have a test button and 5 LEDs on it. If the 1st 3rd and 5th LED flash the battery is bad. ANy any come on solid, then it is a % of charge, each LED = 20%
If you end up replacing hardware, then it will most likely be in this order:
AC Adapter, Battery, Motherboard
Posted on Jun 04, 2009
shadow83
  • 496 Answers
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Posted on Oct 14, 2009
I have A Dell 1720 when I unplug the ac I get a black screen but the laptop is steel running but if I goto safe mode the screen well come on. Replaced battery same problem.
You might have "Sleep mode" or "Blank screen" mode in "on battery status.
Right click on the desktop, click "personalize". Click "Screen Saver", click "Change power settings". Click "Choose when to turn off the display". You will find many options you want "on battery" or "Plugged in".
Hope this helps
May 30, 2014 | Dell Inspiron 1720 17" Widescreen...
Need help trouble shooting stuck on black screen dell inspiron 1720 so ran Diagnostics this is what i get backError code 0148 Msg:error code 2000-0148 Msg: unit 0:Ide error: status 1A error registry 0020h...
Error Code 0148
msg: Error Code 2000-0148
msg: Hard Optical Drive 0 - incorrect status 1 A Error
Register: 0020h
sense information: (02-0401)
sense: 70h 00h 02h 00h 00h 00h 00h 0Ah 00h 00h 00h 00h 04h 01h 00h 00h 00h 00h
Sorry but you have a hard drive issue. Replace the drive.
Mar 10, 2014 | Computers & Internet
I have left and right handed dell a215 speakers but don't know how to connect them
you might need a usb to speaker adapterhttp://www.ebay.com.au/itm/USB-2-0-MIC-Speaker-5-1-Audio-Sound-Card-Adapter-/120645945426?pt=AU_Laptop_Accessories&hash=item1c170f0852
hope this help
Jul 21, 2012 | Dell Inspiron 1720 Notebook, Windows Vista...
My dell inspiron 1720 locks up frequently - this problem started just yesterday I've used CC Cleaner and tried to do a complete virus scan using Kaspersky software - computer locked up at 7% into the...
Try running these scans in Safe Mode.
Keep pressing F8 on startup, and choose 'Safe Mode' from the list that appears.
If you still find it locking up during scans, you may have a hardware problem that needs fixing.
Regards.
Apr 26, 2011 | Dell Inspiron 1720 Notebook
My dell inspiron 1720 hdd password forgot
send me hdd hash code .. turn on laptop u will se a code .. ****4232343-595b or somthing else .. send me that ill send u master password..
Oct 03, 2010 | Dell Inspiron 1720 17" Widescreen...
My dell inspiron 1720 keeps rebooting. Pressed
Yes. You'll need to replace the hard drive with that error code.
No matter you can't use that computer without replacing the hard drive.
If you have a warranty for the computer contact tech support for your dell, give them the error code you have
and they will immediately replace your hard drive.
Re seating the hard drive won't fix it.
Hope this helps!
Feb 21, 2010 | Dell Inspiron 1501 Notebook
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
I have a dell Inspiron 1720. When I boot up it
Replacing the display should solve it.Maybe the inverter but most likely its the display itself.
Oct 04, 2009 | Microsoft Inspiron Notebook
Distorted sound on my dell inspiron 1720
You probably need to reinstall the drivers for it. Visit your manufacturers website to download it.
Open up a browser and go to support.dell.com
Look for anything that says driver and download and click on it.
It will ask you to choose by several options, choose select by service tag. Your service tag can be found on a sticker underneath your laptop.
After you get to the page with the list of available downloads, look for audio, then download and install the one under that.
Hope this helps.
Oct 02, 2009 | Microsoft Inspiron Notebook
Dell Inspiron 1720 Notebook Logo
Alun Cox
