Question about Garden
Power washer isnt getting gas
My craftsman power washer seems like it isnt getting any gas. How do i fix this myself?
4 Suggested Answers
  • 942 Answers
SOURCE: My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Good luck
Regards
PCmania
Posted on Jul 05, 2009
VtToolMan
  • 704 Answers
SOURCE: I am looking for a service manual for a gas
If you have the product model number (located on the tag on the unit) you can follow the attached link and enter in your pressure washer model and then look to the right side of the page and click on the "manual" button to get a copy of the manual you can print or download for free.
Here's a link to a gas powered Sears pressure washer to get you started.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=919762350&productCategoryId=1505000&brandId=0247&modelName=PRESSURE-WASHER&diagramPageId=00001&componentDescription=REPLACEMENT%20PARTS&documentId=10060725&backToLink=Return%20to%20Sub%20Components%20list#partLst
Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
  • 6 Answers
SOURCE: oil to gas mixture for a craftsman 3.75 hp pressure washer
There is universal 2 cycle oil available (pro-mix at Lowe's for example) that is good for all ratios from 16:1 to 50:1. With this oil you add the same amount of oil to the gas independent of ratio required. One gas can, no ratio worries. Hope this helps.
Posted on Oct 03, 2009
Craftsman 2200PSI pressure washer, part #580.752700 dies when trigger off.
NEVER start an engine on a power washer with pump attached. You will damage pump and get no or very little pressure. Replacing pump only fix. Pump for this washer about $49. Check spring on carb for throttle open/close
Jun 10, 2016 | Craftsman Garden
Why is gas tank leaking?
you either have a hole in tank or a hose is bad, take some silicome and patch
Jan 04, 2016 | Garden
How do i remove gas tank cover?
Hey Chuck
Not sure of the model washer you have but most Briggs tank covers only have 2 bolts on top holding the cover to the tank. If the isnt it can you be more specific with a model number?
Feb 20, 2015 | Craftsman 2700 PSI Briggs Stratton...
Oil to gas mixture for a craftsman 3.75 hp pressure washer
Oct 03, 2009 | Briggs & Stratton Garden
My Sears Craftsman power washer won't start. I checked gas and oil. Levels are okay.
Have a 7.0 gas water pressure washer and it won't start. Replaced the spark plug checked the fly wheel and it still won't start.
Sep 02, 2009 | Garden
I washer my Riding mower now it won't start, just no power
Sounds like you may have shorted out a main fuse. The main fuse should either be under the seat where you found that switch or under the bonnet next to the gas tank. Could also be a loose wire going to the solenoid which is also next to the gas tank. Check the solenoid by turning the key on the then use a heavy jumper wire between the two large posts on the solenoid. it should engage the starter, if it doesn't then you have a loose wire somewhere between the battery, ignition or solenoid. Yet again it could also be the key's ignition itself. That should be checked by someone qualified so you don't run the risk of melting something. Very simple test actually and should cost much more than 20 bucks to check it out. Good luck.
Aug 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hp scanjet 3300c will not power up any more .... worked fine the last time used .... is it a matter of replacing a fuse .... can i do it myself?
Of course, check all the power connections and be sure it isnt a bad power adapter, there isnt usually fuses in a printer that can be easily replaced. If its under warranty, use it and get it fixed.
If its just plain unrepairable, just get a new one at walmart or somewhere. I got a new HP all in one that hasnt had any problems since i got it 6 months ago.
Avoid Lexmark or dells printers, They ****
Dec 01, 2008 | HP Computers & Internet
Kenmore he3 not heating
REMOVE 2 SCREWS ON BOTTOM OF PANEL,, REMOVE LINT SCREEN , NOW REMOVE BLACK METAL HOUING ,,,DISCONNCT POWER BEHIND METAL HOUSING THERMAL FUSE IS RIGHT THERE REPL ,NOW SHOULD HEAT UP ,,,2 RED WIRES CONNECT TO IT
Nov 23, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Garden Logo
102 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
