Question about Cosco Juvenile Cosco Sway n Play Swing Zambia
Where do batteries go - Cosco Juvenile Cosco Sway n Play Swing Zambia
I want to put 4 batteries together 4x 12v 7AH. and how many volts and AH would that be.
It depends on how you connect the batteries. If you connect the negative of battery one to the positive of battery 2, the negative of battery 2 to the positive of battery 3 the negative of battery 3 to the positive of battery 4 then the positive of battery 1 and the negative of battery 4 will give you 48v 7AH. (This is known as connecting in series.)
If you connect the four positives together. Connect the 4 negatives together it will give you 12v 28 AH. (This is known as parallel connection.)
If you connect the negative of battery 1 to the positive of battery 2. Connect the negative of battery 3 to the positive of battery 4. Connect the positive of battery 1 to the positive of battery 3 and the negative of battery 2 to the negative of battery 4. You'll get 24v 14AH from the connection of the positive of battery 1 and battery 3, and the negative of battery 2 to battery 4. (This is known as series parallel connection)
Jul 19, 2011 | Electric Cycling
I have 4 x 12v batteries 7ah each. if i put these 4 batteries together . how many volt and AH would this be. please reply . thank you
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Feb 27, 2011 | 1986 Oldsmobile Regency
Where do I replace the battery for a cordless mouse that came with my MK300 keyboard
Q: Changing the batteries in my MK300 trnsp.gif 13634.1.0.jpg How do I change the batteries in my MK300?
Wireless Desktop MK300
Model Number:
Y-R0002 (Keyboard)
M-R0006 (Mouse)
trnsp.gif Battery Requirements:
Keyboard:
  • Requires 2 AAA alkaline batteries.
  • Expected battery life is up to 15 months.
Mouse:
  • Requires 2 AA alkaline batteries.
  • Expected battery life is up to 8 months.
Installing New Batteries
Install the batteries for your mouse and keyboard by making sure the batteries face the correct direction as shown in the image below.
Battery Replacement Tips
  • For best battery performance, always use quality alkaline batteries.
  • When replacing batteries, make sure the replacement batteries are new and are within the manufacturer's expiration date.
  • Do not mix old and new batteries.
  • Do not mix batteries of different brands.
  • Do not use rechargeable batteries in this product.
Jul 25, 2010 | Logitech Cordless Mouse
How about this Pavilion dv8000 Battery for HP Laptop Battery?
You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
Jun 02, 2009 | HP Computers & Internet
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
May 13, 2009 | Nikon D40x Digital Camera
Cosco Juvenile Cosco Sway n Play Swing Zambia Logo
83 people viewed this question
Top Cosco Juvenile Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Cosco Juvenile Baby Gear Expert? Answer questions, earn points and help others
