Question about Motorola Talkabout T5210 2-Way Radio
No volume on radio
Soft volume on one radio
Why will my volume will not go past 10 on my boston duo i plus radio?
To perform a "soft reset"(all settings are erased)
Unplug radio
Hold alarm 1 button and plug in radio
Keep holding alarm 1 button until 3 numbers appear.
Release alarm 1 button and unplug radio.
Plug radio in and all will operate normally
May 21, 2014 | Boston Acoustics Horizon Solo Clock Radio
I am getting a checking media message repeatedly. i did a soft reset by holding up volume and mode key. then a hard reset by touching up arrow then down arrow immedaitely after soft reset. unit still comes...
This is the unit from h**l. I had the same problem. First, make sure you have the latest FIRMWARE update loaded. Next, call Delphi tech support on the radio and they'll have you do the hard reset. Also, you cannot use more than a 2GB micro Memory Card. An 8GB will cause a media problem. Do you get the check media with no card in?
Nov 03, 2009 | Delphi SKYFi3 XM Radio Receiver
Symphony radio goes soft and looses bass at high volume
all that is, is the speapers cant handle the sound
Jul 08, 2009 | 2004 Audi A4
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
Connex 4600 turbo the talk back
THE TALK BACK VOLUME IS CONTROLLED BY THE MIC GAIN, TRY ADJUSTING YOUR TALK BACK VOLUME ABOUT TURNING THE MIC GAIN FROM 12 OCLOCK TO 6 OCLOCK, DO NOT WORRY YOU WILL NOT LOSE ANY OUT BOUND POWER UNLESS YOU TURN THE MIC GAIN BELOW 11 OCLOCK
Mar 29, 2009 | Connex 4600 Base CB Radio
Uniden 5.8 powermax
From the base unit, press the "Menu" soft key.
Press volume up/down button to highlight "Global Setup" and press "Ok" soft key to select it.
Press volume up/down button to highlight "Day and Time" and press "Ok" soft key to select it.
Press volume up/down button to select the day of the week and then press the right arrow soft key.
Press volume up/down button to set hour and then press the right arrow soft key.
Press volume up/down button to set minute and then press the right arrow soft key.
Press volume up/down button to choose AM or PM and then press the SAVE soft key.
You will heart a confirmation tone.
Hope that helps,
Ken
Mar 17, 2008 | Uniden TRU8885-2 Cordless Phone
I just bought a radio transmitter a no # 19-903
maybe the volume control was damage,i suggest,bring it to a qualified technician,if the volume control is damage so we need to replace that part....
Feb 23, 2008 | Radio Communications
No instruction manuel
Hope that helps,
Ken
Jan 19, 2008 | Uniden TRU8885-2 Cordless Phone
Motorola gm300
If you are referring to the receive audio, possibly the reason it is soft/weak are:
1. defective internal speaker - try using an external speaker;
2. volume control - try rotating back & forth till you get satisfactory level. In some cases, you may need to clean the inside of the volume control with an electronic contact cleaner. At worst is that it has to be replaced;
3. defective amplifier - between the volume control and the speaker is the audio amplifier. This is a single op-amp IC U501 (TDA1519A); and/or
4. muting - which is a bit complicated. This is triggered either by the squelch or by the CTCSS tone decoder. You may have partial/false muting. You need to check Q501 (MMBT3904) and its associated circuitry.
Other than #1, most fix would require opening the unit and familiarity with electronic circuitry & components, use of a DVM and soldering iron. Perhaps your best bet would be to seek the services of a qualified communication technician.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 08, 2007 | Motorola EM1000R Two Way Radio
Motorola Talkabout T5210 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
