Question about Kyocera FS-1035MFP
Error C4200 Kyocera FS-1035 MFP Error C-4200
  • 56 Answers
SOURCE: Kyocera FS-2000D
Hi, Sound like drum unit is out off position.
Switch off printer.Open left side door, remove waste toner bottle and push drum unit(with grej lever on it) in printer to proper position.If grey lever is not in proper position, drum will be not locked.Place waste toner bottle in position.Switch on printer.
Posted on Nov 06, 2007
install new firmware
Posted on Dec 18, 2007
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
  • 46 Answers
SOURCE: showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
Posted on Jun 12, 2009
  • 241 Answers
SOURCE: kyocera fs-3900dn showing 7410:0024216 error code
The 7410 is a drum installation error code. This is typically caused when the waste bin is replaced. Open the left door and push on the drum unit just above the waste bin, usualy a click will be heard when pushing it in. Then power cycle the printer. This should fix the error message.
Posted on Jun 09, 2010
My kyocera FS-1035 is displaying error message: The developer unit is not installed. What can I do, it won't allow me to enter the menu
Hello, you need to check that the developer is installed properly. Also check that all the contacts are clean.
How did this error happened?
Nov 25, 2016 | Kyocera FS-1035MFP Printer
I have kyocera km1500 and have a error of 4200 then what is the solution?
Code
C4200
Description
BD steady-state problem
• The MIC detects a BD error for 600 ms after the polygon motor rotation has been stabilized.
Causes
Defective laser diode. Defective polygon motor. Defective main board (KP-5060).
Best Regards
Jul 24, 2016 | Kyocera Office Equipment & Supplies
Kyocera call service 4200:040797
Means that the laser unit is off. You should check the cables for the laser unit
Jun 27, 2014 | Kyocera Mita FS-3820N Laser Printer
Please would you clarify your question and fault?
Mar 19, 2014 | Kyocera FS-1035 MFP/DP Monochrome Printer
My Kyocera FS-1116 MFP says 'printer error'/'engine panic'.
If you get the Engine Panic error message, you need to turn the power switch off and then back on again. If that doesn't fix the error, contact a service representative to help resolve the problem.
Oct 17, 2011 | Kyocera FS-1016 Printer
Error de llamada 7980 en kyocera fs 1016 mfp
Mar 01, 2011 | Office Equipment & Supplies
Kyocera FS-1035MFP Logo
460 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
