Question about ViewSonic VA1916w LCD Monitor
ViewSonic VA1916w LCD Monitor turns black - ViewSonic VA1916w LCD Monitor
SOURCE: No display, green light on ViewSonic VP201b 20.1 LCD
I have two broken VP201 monitors with different symptoms. One was black screen green light - like yours. The other was purple speks flying all over the screen., purple tint.
I swapped the power supplies and display boards, both monitors had original problems. I swap the inverters and the monitor which was black screen now appeared to work okay - but slightly pink and the monitor which was purple speks is now black screen.
I would therefore assume that both my inverters gone, one being on it's way out. You probably have the black-screen case.
Posted on Aug 27, 2008
SOURCE: viewsonic VA720 monitor has small blinking light, won't turn on
When turning on the computer we get analog auto save, and don't get as far as the desktop, how can I solve this problem
Debi
Posted on May 04, 2009
rulds2008
  • 3866 Answers
SOURCE: Viewsonic VP2030b LCD monitor - No power
There should be one fuse in the power supply inside. You can check and replace that if its dead. now if its not dead and you got power to that point you do need to rule out any capcitors at that time but if the fuse is gone it will not hurt to check the rest of the supply for the fault.
Please rate and accept the answer if it did help.
Posted on Aug 18, 2009
budmrtn
  • 11361 Answers
SOURCE: Viewsonic VA912b. Monitor will only turn on for a
Bad caps in the power supply, common problems. See examples here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20V912B/
Posted on Jan 07, 2010
budmrtn
  • 11361 Answers
SOURCE: my ViewSonic VG1930WM (Black) LCD Monitor wont turn on
You need to open it up and the first place to look will be the power supply, look for bad caps with bulging top, post back what you find so we can guide you further. See example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 01, 2010
View sonic va1916 removing stand
Read this:
http://www.manualslib.com/manual/266476/Viewsonic-Vx2640w.html?page=10#manual
Apr 20, 2014 | ViewSonic VA1916w LCD Monitor
I have a Viewsonic VA1916W-4 monitor and it has been working perfectly until today when the display went all green. I'm using it as a second monitor to supplement my laptop, which does not have the...
We had a similar problem with a bigscreen TV. We feared the worse, but after calling our local repair service, they told us this was a common problem involving a poor solder joint. They came out and fixed it in 15 minutes. Start by Googling your model number and "green" or "troubleshoot" to see if this is a common problem. If so, you may be able to fix it yourself or print out the issue and take it to a reputable repair shop or authorized dealer.
Sep 27, 2017 | ViewSonic VA1916w LCD Monitor
My monitor/CPU has a problem; I'm not sure yet but here's the symptoms: When I boot my desktop, my monitor goes on then after a while, it just goes black and says "No Signal" then suddenly the...
Sorry to read about your problem, I hope this helps you out.
make life easy and take the monitor to a friend, plug it in and see if it works....or if you have a old monitor around. plug that in...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | ViewSonic VA1916w LCD Monitor
Monitor turn on button is stuck
The monitor screen is black can be caused by bad caps in the power supply, bad inverter circuits, or worst will be bad lamps, you need to open it up and look at the power supply for bad caps first, look for caps with bulging top or bottom seal and then report back so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 04, 2010 | ViewSonic VA1916w LCD Monitor
Screen is black with power light on. It worked when I turned it off on Friday and now on Sunday when I turned it on there was no video. I moved this monitor to another working computer and it did not work....
The problem is with the monitor. Try to check its cables if properly plugged in.
If the problem is still there, then you might want to have a service center check the monitor.
Jul 20, 2009 | ViewSonic VA1916w LCD Monitor
No sound
you need to reinstall your soundcard on the computer
Dec 06, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
No sound
Have you connected the audio cable from the PC soundcard to your monitor?
Apr 13, 2008 | ViewSonic VA1916w LCD Monitor
ViewSonic VA1916w LCD Monitor Logo
42 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
