Question about Honeywell Dolphin 9700
Honeywell 9700 When I turn off the device, it loses all settings and deletes the installed systems. What is the procedure should I do to avoid this?
Delete contacts on blackberry bold 9700
As long as you haven't done anything on the phone yet, you can do a factory reset. To do so, you go into the settings > security > security wipe, and check any boxes. Type blackberry and hit Wipe Data.
Jan 28, 2014 | RIM BlackBerry Bold 9700 Smartphone
Tip
Various tips
tp.gifSOLUTION: Hold On/Off switch until it resets
tp.gifSOLUTION: Turn Off iPhone; Power it back up
tp.gifSOLUTION: : Reset TomTom One at least once, Sometimes several times to power up
SOLUTION
  • Ok... there is a trick to this. I set it up EXACTLY the same way with the AT&T option and the Cingular option. The only way it works is with the CINGULAR option.
tp.gif1.replace the APN isp.cingular with
tp.gif wap.cingular
tp.gif2.delete default username, type tp.gif WAP@CINGULARGPRS.COM
tp.gif3.delete default password, type
tp.gif CINGULAR1
tp.gif4.when the login script comes up it should look
tp.gif ike this (because you've already changed the APN)
tp.gif at+cgdcont=1,"IP","wap.cingular"
tp.gif5.Accept the automatic configuration for the IP & DNS
on Feb 07, 2010 | Cell Phones
Garmin 2460 - when I upgrade the maps, I lose all stored favorites (except Home) and it's a pain to re-enter. Any way to avoid this?
Yes, back up your favorites. First, your GPS really should not be losing your favorites during an update (some firmware upgrades can cause this). We have written a procedure to back up your favorites should you lose them. The procedure can be found here:
http://www.sharc.net/discus/messages/6/411.html?1349855368
Sep 14, 2013 | Garmin Nuvi 2460lmt Gps Navigation System...
I got a error 523 on my blackberry bold 9700
error 523 reset means a "System process died" You'll need I would reload the entire handheld OS again.
1. Install the software from the CD (that you received with the device), or download it from the service provider (AT&T).
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Red Pearl (since am sure that's what you have!)...
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
But, since this has happened so many times, I have to ask myself, is it something you're doing that it causing this? I know the Red Pearls from AT&T have had issues from DAY ONE!
Jan 04, 2011 | RIM BlackBerry Bold 9700 Smartphone
I have sony ericson xperia x10 but when i tried to transfer files using bluetooth to my friend's black berry 9700 word appear "paired but not connected" may i know what will i do to fixed it....
Have you & him trusted both the devices first?
Sometimes this has to be done for the good smartphones that have secure wi-fi settings defaulty installed on the systems from manufacturers.
Go to your Connections settings.
Select: "Trusted Devices" if you have that one or similar wording.
Make sure your friends 9700 is selected as a Trusted Device so that you'd be able to pair information across.
Jan 01, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Blackberry bold 9700 showing app error 523
With regards to your issue, error 523 reset means a "System process died" You'll neeD to reload the entire handheld OS again.
Here is how you go about it;
1. Install the software from the CD (that you received with the device), or download it from the service provider.
Problem solved
Thanks and take care..
Aug 04, 2010 | RIM BlackBerry Bold 9700 Smartphone
My sound card was accidently deleted , I was wondering what kind I need so I can re install it
follow this dell link
  • http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R91865&formatcnt=0&libid=0&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=119690
How to Install Dell Inspiron 9200 notebook ATI Mobility Radeon 9700... This step-by-step guide describers how to obtain and install Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP drivers for Windows.
1. Define your Dell Notebook device model.
2. Define your operating system to install your Dell Notebook device. Note: Update Drivers in Win Vista
3. Browse Notebook Drivers.
4. Find Dell Notebook Drivers.
5. Select Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP.
6. Download Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
Jun 05, 2010 | Dell Inspiron 9200 Notebook
Forgot password,just reset my blackberry bold 9700
i typed in a wrong password 10 times and my blackberry automatically wiped off most of my data, how do i restore them please
Apr 05, 2010 | RIM BlackBerry Bold 9700 Smartphone
Blackberry Bold 9700 - RELOAD SOFTWARE 513
all you need to do is sync your blackberry with your blackberry desktop manager and run the application loader. you will lose all data on the phone because you will be re-installing the software
Feb 28, 2010 | RIM BlackBerry Bold 9700 Smartphone
Bold9700 turn itself off and unable to turn on eventhough the battery is full
Replacing the firmware of these devices can correct all kinds of irratic behavior. I recommend installing the most recent system software. The latest BlackBerry Bold 9700 system software is available through here.
Feb 13, 2010 | RIM BlackBerry Bold 9700 Smartphone
Honeywell Dolphin 9700 Logo
23 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
